Delay question
Results 1 to 22 of 22
Thread: Delay question
    Feb 2003
    Salt Lake City, Utah USA
    Red face
    Henrik,
    My apologies - you are and were indeed correct (166.667 / 2 != 833.33).
    I am guessing the 16F PBP compiler code is not optimized to check to see if it is in the same page as the goto. I bet it sets the PCLATH every time it encounters a goto just to be safe. I do not think it would add PIC code - I think it would take more compiler code to do this check - MELABS must not have thought it was not worth it to potentially save one instruction (100% guess by me)?
    Paul Borgmeier
    Salt Lake City, UT
    USA
    __________________
    I think it will use the CHK?RP macro simply for safety sake. sure the code is not optimized in any sort, but it's always solid as rock. When you need something tight, use ASM. Hence, for safety sake and for none 18Xxxxx your asm example could be...
        CHK?RP    ; make sure we are on the right BANK
    here
        bsf PORTB,1
        NOP
        NOP
        bcf PORTB, 1
        goto here
    PORTB.1=0 call MOVE?CT macro. wich is
    MOVE?CT macro Cin, Regout, Bitout
            CHK?RP  Regout
        if (((Cin) & 1) == 1)
            bsf     Regout, Bitout
            bcf     Regout, Bitout
    there you discover the extra cycle
    Jan 2007
    separate coil-capacitor Oscillator and use pic only to turn on and of this oscillation we will get Pulse Modulation
    Jan 2007
    it sound too simple to be true
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 07:57
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 15:23
  3. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 16:34
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 19:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 00:10
