Therian,
Well, let's see:
This, I think, will generate a pulsetrain with 50% duty cycle. The frequency would be ~833kHz. Not much of a radio frequency.... besides that, you can't do anything else in the code without slowing it down more...much more.Code:Start: PortB.1 = 1 'Set pin high @ NOP 'Wait....Two NOP's are neede if we want 50% dutycycle @ NOP 'since the GOTO takes two instruction cylcles. PortB.1 = 0 'Set pin low Goto Start 'Do it again. The GOTO takes the same time as two NOP's
/Henrik Olsson.
