Delay question
Results 1 to 22 of 22
Thread: Delay question
    Come on Skimask
    Jan 2007
    Can someone please explain me how to use assembly to make shorter delay than pauseus can make ?
    The shortest possible delay is achieved by using the assembler command NOP (short for No OPeration):
    @NOP       'Delay for OSC/4
    The NOP instruction takes 1uS at 4Mhz and 250nS at 20Mhz etc. If you want longer delay add more NOP instructions or build a loop, but then it's probably easier to use PauseUs anyway.
    /Henrik Olsson.
    Jan 2007
    thank you, as i understand 1us is minimum limit for 4mhz crystal
    Therian,
    Yes, that is correct. With a 4Mhz X-tal one intruction cylce is 1uS and since the NOP command takes one cycle to execute the delay will be 1uS.
    /Henrik Olsson.
    Jan 2007
    just curious, is 250nS enough to generate radio frequency directly from pic without any rf modules, it sound like cheap radio link
    Therian,
    Well, let's see:
    Start:
      PortB.1 = 1     'Set pin high
    @ NOP             'Wait....Two NOP's are neede if we want 50% dutycycle
    @ NOP             'since the GOTO takes two instruction cylcles.
      PortB.1 = 0     'Set pin low
    Goto Start        'Do it again. The GOTO takes the same time as two NOP's
    This, I think, will generate a pulsetrain with 50% duty cycle. The frequency would be ~833kHz. Not much of a radio frequency.... besides that, you can't do anything else in the code without slowing it down more...much more.
    /Henrik Olsson.
  1. 16F628A - Stops if release power switch.
    By dene12 in forum General
    Last Post: - 14th February 2009, 08:57
  2. Old and beyond help ?
    Last Post: - 11th December 2008, 16:23
  3. RF Transmitter
    By et_Fong in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 17:34
  4. Memory Space of the PIC16F84...
    By Tear in forum mel PIC BASIC Pro
    Last Post: - 1st July 2005, 20:55
  5. Problem with saving to EEPROM...
    Last Post: - 1st July 2005, 01:10
