Help....
Results 1 to 4 of 4
Thread: Help....
    you didn't tell us your osc speed, but i'll assume 4MHZ
    use the following setting and post your results
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 0.16%
    Those lines above, are a courtesy of Mister E PICMultiCalc
    Zah Mister E PicMultiCalc... the calc who calc those calcs
    and this...
    ME:
    High TXD
    HSerout["ATX=[2]"] ' busy line
    Pause 2000
    Low TXD
    Pause 2000
    HSerin 500,ME,[wait("OK")]
    probably a real killer and also golden to miss incomming data., remove the pause 2000
    Eng. Baby heart's Avatar
    Eng. Baby heart Guest
    Mister_e, thank you for your reply.
    The oscillator value you assumed was right 4MHz, but the main problem is in the dial function.
    I wish you could help me in that
    Best Regards,
    Eng. Baby Heart
    sure if your RCSTA and TXSTA setting wasn't good, it will never work. And you probably need a MAX232 between your modem and your PIC.
    I didn't read the 266 pages of the modem manual (Available here), but it state it use ATA command, so i guess those you have in your code are good... i said i guess, i think i hope....
    Don't give up!
