Help....
Results 1 to 4 of 4
Thread: Help....
    Eng. Baby heart's Avatar
    Eng. Baby heart Guest
    Default Help....
    I am working on a project and wrote the following program but there was no response, so i wish that someone could help me in that?
    DEFINE LOADER_USED1 'only required if bootloader is used to program PIC
    DEFINE HSER_RCSTA 18h 'set recieve register to reciever enabled
    DEFINE HSER_TXSTA 98h 'set transmit register to transmitter enabled
    DEFINE HSER_BAUD 9600 'set baud rate
    DEFINE HSER_SPBRG 99h 'set SPBRG directly
    DEFINE HSER_CLROERR 1
    INCLUDE "modedefs.bas"
    init:
    TRISA=%111000 ' set port A status
    TRISB=%10000010 ' set port B status
    PORTA=%000000 'inital state of port A
    PORTB=%00000000 'initial state of port B
    freq VAR WORD
    dur VAR WORD
    Lock VAR PORTB.4
    GoSub Dial
    GoSub ME
    freq=4000
    dur=2000
    GoSub latch
    Dial:
    IF PORTB.1 = Low Then
    HSerout["AT"] 'Initialize the Modem
    Pause 500
    HSerout["ATD0505969798;"] 'Store number
    Pause 500
    HSerout["ATDME0505969798;"] 'Dial the stored number
    Pause 500
    End IF
    ME:
    High TXD
    HSerout["ATX=[2]"] ' busy line
    Pause 2000
    Low TXD
    Pause 2000
    HSerin 500,ME,[wait("OK")]
    IF PORTC.7 Then
    GoSub msg
    Else
    High TXD
    Pause 2000
    HSerout["ATH"]
    Low TXD
    Pause 2000
    EndIF
    msg:
    RXD=0
    High PORTB.0
    Pause 2000
    Sound PORTB.0,[dur,freq] 'play msg on intercom
    Pause 6000
    Low PORTB.0
    Pause 2000
    latch:
    DTMFOut PORTB.1,[2]
    IF PORTB.1 Then
    High Lock
    Pause 2000
    Else
    Low Lock
    Pause 2000
    EndIF
    Note: I used GM29 Sony Ericsson modem and PIC16f876 micochip.
    Best Regards,
    Eng.Baby heart
    you didn't tell us your osc speed, but i'll assume 4MHZ
    use the following setting and post your results
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 0.16%
    Those lines above, are a courtesy of Mister E PICMultiCalc
    Zah Mister E PicMultiCalc... the calc who calc those calcs
    and this...
    ME:
    High TXD
    Pause 2000
    Low TXD
    Pause 2000
    probably a real killer and also golden to miss incomming data., remove the pause 2000
    Mister_e, thank you for your reply.
    The oscillator value you assumed was right 4MHz, but the main problem is in the dial function.
    I wish you could help me in that
    Best Regards,
    Eng. Baby Heart
    sure if your RCSTA and TXSTA setting wasn't good, it will never work. And you probably need a MAX232 between your modem and your PIC.
    I didn't read the 266 pages of the modem manual (Available here), but it state it use ATA command, so i guess those you have in your code are good... i said i guess, i think i hope....
    Don't give up!
