Split decimal digits
Results 1 to 11 of 11
    Jan 2006
    Question Split decimal digits
    Anybody who has an idea on how to split the value of a 4-digit word variable into ones, tenths, hundreths and thousands.
    Example:
    The program is performing counting from 0 to 9999.
    Counter Var Word
    Assuming Counter has a value of 5389.
    I'm planning to store 9 to Digit1s variaible
    8 to Digit10s variable
    3 to Digit100s variable
    5 to Digit1000s variable
    I tried using DIG operator, only the first two decimal digits are correct (ones & tenths).
    Is there any mathematical method of splitting decimal digits?
    Feb 2005
    Kolkata-India
    Default DIG works for me at least
    It works for me. Can you post more of your code I always use it for my Seven Segment Display Routines. http://www.melabs.com/resources/pbpmanual/4_0.htm#4177
    Sougata
    The DIG operator should work for that, I can't say why it doesn't work for you. A mathematical way may be:
    Counter var word
    Thousands var byte
    Hundreds var byte
    Tens var byte
    Ones var byte
    Counter = 5389
    Thousands = Counter / 1000                       'Thousands is now 5
    Counter = Counter - (Thousands * 1000)      'Counter is now 389
    Hundreds = Counter / 100                           'Hundreds is now 3
    Counter = Counter - (Hundreds * 100)          'Counter is now 89
    Tens = Counter / 10                                  'Tens is now 8
    Ones = Counter - (Tens * 10)                     'Ones is now 9
    /Henrik Olsson.
    DIG work, have a look at the following
    http://www.picbasic.co.uk/forum/showthread.php?t=1044
    Jan 2006
    Default emavil's reply
    thanks a lot guys, i think there's a minor glitch with the programming.
    It's working now with DIG.
    But the mathematical approach was good.
    Jan 2007
    Dig is great function but how to find out how many digits in the number if you dont know it, and what Dig function will do if you try to asses position what do not exist ?
    W0 = 54321
    B1 = W0 DIG 6 <---?
  1. DS1820 display with 7-seg 4 digits
    By chai98a in forum Code Examples
    Last Post: - 10th April 2008, 14:12
  2. Time display on 7-seg 4 digits
    Last Post: - 5th March 2007, 08:24
  3. hex ascii help please
    By ffr58kk90 in forum mel PIC BASIC Pro
    Last Post: - 29th December 2006, 22:09
  4. 16bit variable and degrees conversion
    Last Post: - 2nd May 2005, 18:27
  5. Decimal to binary conversion
    By Demon in forum Code Examples
    Last Post: - 25th February 2005, 21:05
