Changing position of program code
Results 1 to 18 of 18
    Default Yea, why?
    Quote Originally Posted by sayzer
    Why someone would want to start a code at page boundary?
    May be I need to learn that.
    I gotta parrot sayzer, why is that important? Are you trying to find out what code to leave off in order to use a pic with less space?
    JS.
    Curiousity killed the cat
    Satisfaction brought him back.
    I know about the compiler warnings. I have now re-arranged some code and removed a subroutine, it is now 4.7k and does not have problems.
    Thanks for the comments.
    Wink You are not dreaming !!!
    Hi, Aerostar
    I've already noted some troubles as you describe ... diseappearing when subs are re-arranged !!!
    Generally when subroutines are placed at the end of the program , not so far from boundary limits ... ( If - Then tests not working i.e. )
    I wrote a thread about that in those columns ... but no definitive answer !!!
    Can't find a satisfying explanation to that ...
    Quote Originally Posted by Acetronics
    Hi, Aerostar
    Now that's different...I've always put my sub's at the beginning of the program and jumped over them and haven't had a problem. Huh... even more unsatisfying isn't it?
    JDG
    On older version of PBP there was an issue with the placement of sub's. I think it was prior to 2.32. After that there was no limit as to where one can put his sub's. BUT, I found that rearranging the subs, there was a great improvment on the final code size.
    I suppose this is explained considering the boundary limits and the asm commands used by the compiler.
    Jan 2006
    Istanbul
    So in this case, where do we put the subs then?
    Based on what criteria do we arrange the subs?
    Hi Sayzer. Well, now there is no official directive as to where is better placed a sub. According to old practice, on top. But this does not affect in any way the execution.
    I only pointed out that if one has 5 sub's for example, and have different sizes, rearranging the order of them is affecting the final code size. I think is because a bigger sub might fall between two pages while others won't.
    After a little experimenting you can find that your code might reduce up to 20% or more! Also if you change your variables to be placed on BANK0 also may help. Especially if there are arrays in the program. I had a program reduced from 7540 bytes to 6200 using the above!
  1. DS1307 and a LED array, need ideas
    By peu in forum mel PIC BASIC Pro
    Last Post: - 30th December 2009, 19:45
  2. Problem runing my code
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 21:36
  3. Making Program Code Space your playground...
  4. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 20:51
  5. Replies: 7
    Last Post: - 25th July 2006, 16:11
