Changing position of program code
Results 1 to 18 of 18
    Default Changing position of program code
    I want to start some code at a page boundary, I cannot see a command in PBPRO to do this, I am using PB2.43, 16f876a, and there does not seem to be anything after using the search in this and the old list. Perhaps I am not putting in the correct words !.
    eg code
    org 1000h
    code
    It's kinda dangerous but you can use
    @ ORG 1000h
    your code here
    Jan 2006
    Istanbul
    Why someone would want to start a code at page boundary?
    May be I need to learn that.
    Default Yea, why?
    Quote Originally Posted by sayzer
    I gotta parrot sayzer, why is that important? Are you trying to find out what code to leave off in order to use a pic with less space?
    JS.
    Curiousity killed the cat
    Satisfaction brought him back.
    I know about the compiler warnings. I have now re-arranged some code and removed a subroutine, it is now 4.7k and does not have problems.
    Thanks for the comments.
    Wink You are not dreaming !!!
    Hi, Aerostar
    I've already noted some troubles as you describe ... diseappearing when subs are re-arranged !!!
    Generally when subroutines are placed at the end of the program , not so far from boundary limits ... ( If - Then tests not working i.e. )
    I wrote a thread about that in those columns ... but no definitive answer !!!
    Can't find a satisfying explanation to that ...
    Thanks for the reply, I will try it out tomorrow.
    I am trying to debug some code which appears to fall over around the 1000h boundary, so by making some of the code start after the boundary and not cross it I can then perhaps make a more educated guess as to what I have done wrong.
    Feb 2003
    Quote Originally Posted by aerostar
    Do you have any BRANCH instructions in there ?
    Keith
    www.diyha.co.uk
    www.kat5.tv
    If you're getting the 'cross page boundary' warning, that's all it is... a warning. PBP takes care of business for you.
    Nothing to worry about.
    JDG
  1. DS1307 and a LED array, need ideas
    By peu in forum mel PIC BASIC Pro
    Last Post: - 30th December 2009, 19:45
  2. Problem runing my code
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 1st December 2009, 21:36
  3. Making Program Code Space your playground...
  4. Code: Why is this code greater than 2000 words?
    By DrDreas in forum mel PIC BASIC Pro
    Last Post: - 1st June 2007, 20:51
  5. Replies: 7
    Last Post: - 25th July 2006, 16:11
