help!! With Keypad change
Results 1 to 4 of 4
    clare1's Avatar
    clare1 Guest
    Angry help!! With Keypad change
    Hello All
    I am a newbie when it comes to picbasic i am still learning the basics of it
    so please dont be too hard on me.
    I writting to find out if there is any examples of interupt on portb change
    i am using pic16f877 and LAB-X1 Experimenter Board
    i have got an example of using the key pad as below and it works fine
    But the problem is that i have already sent it out to my brother in africa
    before he told me that they are only going to be using SW1,SW2 & SW3
    Wired as nornally open contacts .
    The problem with that is the way the example problem works is that
    when the using presses the button, it only activates after you have released the button.
    Question :
    How can i modified the code so that it works when the button is pressed
    the different test1 , test2 & test3 to activate
    would i have to use portb change
    Please Help
    Clare1
    ' PicBasic Pro program to display display the following when the
    ' SW1 = EARTH BOND
    ' SW2 = FLASH TEST
    ' SW3 = IR TEST
    DEFINE LOADER_USED 1 ' uses a bootloader
    @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HSPLL_OSC_1H
    ' @ __CONFIG _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
    INCLUDE "Modedefs.Bas"
    Define OSC 20
    clear
    ' Setup Hardware for uart/RS232
    DEFINE HSER_BAUD 9600
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_CLROERR 1
    ' End of Setup Hardware for uart/RS232
    'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    'Start of LCD Setup
    DEFINE LCD_DREG PORTD ' Use Portd for LCD Data
    DEFINE LCD_DBIT 4 ' Use Upper(4) 4 bits of Port
    ' PORTD-4 thru PORTD-7 connects to
    ' LCD DB4 thru LCD DB-7 respectively
    DEFINE LCD_RSREG PORTE ' PORTE for RegisterSelect (RS) bit
    DEFINE LCD_RSBIT 0 ' PORTE-0 pin for LCD's RS line
    DEFINE LCD_EREG PORTE ' PORTE for Enable (E) bit
    DEFINE LCD_EBIT 1 ' PORTE-1 pin for LCD's E line
    DEFINE LCD_BITS 4 ' Using 4-bit bus
    DEFINE LCD_LINES 2 ' Using 2 line Display
    DEFINE LCD_COMMANDUS 2000' Command Delay (uS)
    DEFINE LCD_DATAUS 50 ' Data Delay (uS)
    ' ** Define LCD Control Constants **
    I CON 254 ' Control Byte
    Clr CON 1 ' Clear the display
    Line1 CON 128 ' Point to beginning of line 1
    Line2 CON 192 ' Point to beginning of line 2
    Line3 Con 148 ' Point to beginning of line 3
    Line4 Con 212 ' Point to beginning of line 4
    'End of LCD Setup
    ' ** Setup the ADCIN Defines **
    DEFINE ADC_BITS 10 ' Set resolution of conversion
    DEFINE ADC_CLOCK 2 ' Set clock source (x/FOSC or FRC)
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time (in uS)
    ' Define program variables
    col VAR BYTE ' Keypad column
    row VAR BYTE ' Keypad row
    key VAR BYTE ' Key value
    disp_key VAR BYTE ' Key ASCII value
    INTCON2.7 = 0 ' Enable PORTB pullups (18F452)
    ADCON1 = 7 ' Make PORTA and PORTE digital
    TRISB=0
    portd=0
    Pause 1000 ' Wait for LCD to start
    loopp:
    lcdout I,Clr:Pause 30
    LCDOut I,Line1," Press A key To Test" ' Display sign on message
    lcdout I,Line2," S1= Earth Bond Test"
    lcdout I,Line3," S2= Flash Test "
    lcdout I,Line4," S3= DC IR Test"
    loop:
    GoSub getkey ' Get a key from the keypad
    IF key != $FF Then ' Check to see if a key was pressed
    IF (disp_key <>"1") and (disp_key <>"2") and (disp_key <>"3")then loop
    'Block response from other key press outside S1-S3
    ' Loop back to loop if other keys are pressed
    LCDOut $fe, 1, disp_key ' Display ASCII key label
    if disp_key = 49 then Earth_Bond 'dec value for ascii 1
    if disp_key = 50 then Flash_Test 'dec value for ascii 2
    if disp_key = 51 then IR_Test 'dec value for ascii 3
    EndIF
    'if disp_key > "3" then key = $FF
    'if disp_key < "1" then key = $FF
    ' <> or !=
    GoTo loop ' Do it forever
    ' Subroutine to get a key from keypad
    getkey:
    ' Check for keypress
    For row = 0 TO 3 ' Loop for 4 rows in keypad
    PORTB = 0 ' All output pins low
    TRISB = ~(DCD row) ' Set one row pin to output
    @ NOP ' Fudge for 18F452
    col = PORTB >> 4 ' Read column pins
    IF col != $0F Then ' Check if key is pressed
    GoTo gotkey ' If any keydown, exit
    EndIF
    Next row ' Repeat for the next row
    key = $FF ' No keys down, set key to $FF
    Return ' Return to main loop
    gotkey: ' Change row and column to key number 0 - 15
    Pause 50 ' Debounce
    ' Wait for all keys up
    TRISB = $F0 ' Least significant 4 pins out, top 4 pins in
    IF ((PORTB >> 4) != $0F) Then gotkey ' If any keys down, loop
    key = (row * 4) + (NCD (col^$0F)) - 1 ' Combine row and column into numeric value
    ' Translate key to display label:
    ' 1 2 3 A
    ' 4 5 6 B
    ' 7 8 9 C
    ' * 0 # D
    LookUp key,["123A456B789C*0#D"],disp_key
    Earth_Bond:
    high portd.0
    lcdout I,Line1," Earth_Bond "
    lcdout I,Line2," Test "
    hserout [" EarthBond Test ",10,13]
    low portd.0
    Flash_Test:
    high portd.1
    lcdout I,Line1," Flash_Test "
    lcdout I,Line2," HV "
    hserout [" Flash_Test",10,13]
    low portd.1
    IR_Test:
    high portd.2
    lcdout I,Line1," Insulation_Test "
    hserout [" IR_Test",10,13]
    low portd.2
    goto loop
    brighton
    You would have to use portb change interupt.
    You could even use DT instant interuptS
    Isaac
    Jan 2006
    Istanbul
    Quote Originally Posted by clare1
    Question :
    There is something called "Rising Edge" and also "Falling Edge".
    You check what these are first.
    Then you will know how to set a button when it is pressed or after it is released.
    brighton
    Cool
    Hi Clare
    Just a thought . For your application you said your were using the LAB-X1 Experimenter Board and that you are only interested in SW1-SW3
    if that is the case you don't even need to use the PortB change interupt
    you can do something like this and it should work give it a go
    Isaac
    ' PicBasic Pro program to show button press on LED
    ' Define LOADER_USED to allow use of the boot loader.
    Define LOADER_USED 1
    OPTION_REG = $7f ' Enable PORTB pull-ups
    loop:
    PORTB = 0 ' PORTB lines low to read buttons
    TRISB = $f0 ' Enable all buttons
    ' Check any button pressed to turn on LED
    If PORTB.4 = 0 Then ' If 4th button pressed...
    pause 50
    if PORTB.4=0 Then
    gosub Earth_Bond
    Endif
    Endif
    If PORTB.5 = 0 Then ' If 3rd button pressed...
    pause 50
    if PORTB.5=0 Then
    gosub Flash_Test
    Endif
    Endif
    If PORTB.6 = 0 Then ' If 2nd button pressed...
    pause 50
    if PORTB.6=0 Then
    gosub IR_Test
    Endif
    Endif
    Goto loop ' Do it forever
    Earth_Bond:
    'your stuff here
    Flash_Test:
    'your stuff here
    IR_Test:
    'your stuff here
  1. 4x4 keypad Help
    By aaliyah1 in forum mel PIC BASIC Pro
    Last Post: - 5th October 2010, 17:34
  2. Keypad input test
    By Kalind in forum mel PIC BASIC Pro
    Last Post: - 8th October 2008, 05:00
  3. Need help in matrix keypad coding
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 24th May 2008, 14:16
  4. Inconsistent output on a 4x4 matrix keypad
    By markcadcam in forum mel PIC BASIC Pro
    Last Post: - 24th November 2006, 04:54
  5. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
