16 bit a/d support
Results 1 to 4 of 4
    Jun 2006
    Glasgow, Scotland
    Smile 16 bit a/d support
    I have just purchased PicBasicPro and would like to use it in a project I am about to start. I have most of the code already written in asm for the Pic16C57 which I eventually managed to convert to the 16F57. I would like to know if anyone has used the pic16F877A with a 16 Bit ADC Convertor (2 channels preferred). The 10 bit ADC on the pic16f877a is not ghood enough.
    thanks in advance John
    Feb 2005
    Kolkata-India
    Default Which ADC do you want to use
    You have not mentioned the ADC chip you would be using.
    Sougata
    Jun 2006
    Glasgow, Scotland
    hi sougata, I dont have any particular in mind, except that the sample rate is better than 50 sps for two channels and it is a DIP package. The input voltage can be anything between 0-10mV to 0-10vdc. I was looking at the possibly of using the AD7705. It has to be readily available.
    thanks again John
    Feb 2005
    Kolkata-India
    Default Seems a good choice
    A quick glance at the datasheet seems it to be a good choice considering the onboard PGA. However for larger input signals you may need to use input attenuation. Serial interface is easy to handle in PBP too.
    Best of Luck.
    Sougata
    Last Post: - 14th June 2016, 07:55
  2. MCP3208 12 bit A/D driver
    By polymer52 in forum Code Examples
    Last Post: - 5th February 2010, 11:59
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. Melabs PIC Basic Pro - 16 bit devices support
    By rod27cn in forum PBP Wish List
    Last Post: - 21st November 2007, 08:21
    Last Post: - 6th March 2005, 01:07
