Any problem in declaring and using VARs longer than 512 bytes?
Results 1 to 5 of 5
    Feb 2005
    Kolkata-India
    Default In PBP arrays cannot span across banks
    Since one bank of data RAM can hold 256 bytes only you cannot span arrays across banks. So splitting it up is the only way perhaps. Using C18 has its own benefits of a better memory management than PBP for both global and local variables. Also it uses a software stack that depends on the free RAM you have and can be always bigger than the hardware stack. You can always create a subroutine for your data access that automatically chooses the specific bank depending on your array index and dumps it to a temporary variable. This should not complicate things much.
    Sougata
    May 2006
    Del Rio, TX, USA
    MaxG,
    I have successfully used a 528 byte long array for datalogger using the same 18F4620 (plus I had 2 that were 512 long, all in the same program). There is no problem with spanning banks on the 18F in PBP that I have found.
    Here is a quote from the PBP manual: "Arrays may span banks on 18Cxxx devices. Byte- and word-sized arrays are only limited in length by the amount of memory"
    SteveB
    Default Variables
    I built an MP3 player, used a PIC18F4620, and if I remember right I used up practically all of the onchip ram in one word variable:
    sectorbuffer var word[1536], or maybe it was more than one. I'll check when I get home tonight.
    Easiest way is to just write the program and compile it. If you get an error, you can't.
    Wish I had more instant info for ya....
    JDG
    Feb 2005
    Kolkata-India
    Default Sorry I missed the 18Fxxx issue
    Hi All,
    Sorry I missed that the used chip is a PIC18. It does have a linear addressing for the RAM location.
    Arrays must fit entirely within one RAM bank on most PICmicro MCUs.
    They may not span RAM banks on 12-bit, 14-bit or 17Cxxx devices.
    (Arrays may span banks on 18Xxxx devices. Byte- and word-sized
    arrays are only limited in length by the amount of memory.) The
    compiler will assure that arrays will fit in memory before successfully
    compiling.
    Define your array to a specific bank such that it spills over to the next bank.
    Sougata
