18F1320 And I/0
Results 1 to 4 of 4
Thread: 18F1320 And I/0
    Feb 2005
    Default 18F1320 And I/0
    Hi
    I want to put all I/O pins of 18f1320 as I/0 digital.
    i´m defining it like this
    ADCON1=%01111111
    But Pin2(RA0/AN0) is erratic!
    What i´m doing wrong?
    You should have it good, but can you post your code?
    Anyways... the following work here on a EasyPIC 4 board
    asm
        __CONFIG    _CONFIG1H, _XT_OSC_1H
        __CONFIG    _CONFIG2H, _WDT_OFF_2H
        __CONFIG    _CONFIG4L, _LVP_OFF_4L
    endasm
    PORTA=0
    TRISA=0
    PORTB=0
    TRISB=0
    ADCON1=%01111111
    ByteA var byte
    Start:
        '   LED show on PORTA
        for bytea=0 to 4
            PORTA = DCD BYTEA
            PAUSE 200
            NEXT
        TRISA=255    ' turn PORTA as input
    Spin:
        PORTB=PORTA  ' display PORTA push button status on PORTB
        GOTO Spin
    Feb 2005
    This is my code:
    '{$STAMP BS2p}
    define osc 4
    ADCON1=%01111111
    'CONSTANTES DE INICIALIZAÇÃO e controlo 1-wire
    OW_FERst CON %0001 'Front-End Reset
    OW_BERst CON %0010 'Back-End reset
    OW_BitMode CON %0100
    SkipROM CON $CC 'Skip ROM Command
    WriteScratch CON $0F 'Write ScratchPad
    CopyScratch CON $55 'Copy ScratchPad to Memory
    ReadScratch con $AA
    ReadMemory CON $F0 'Read Memory
    SearchROM CON $F0
    Validation_Key CON $A5
    Endereco_Inicial CON $00 'Target Address in Memory
    ReadROM CON $33 'Read ROM Command
    CopyLockAppReg CON $5A
    ReadStatusReg CON $66
    'CONSTANTES DE INICIALIZAÇÃo e controlo LCD
    clrLCD CON 12 ' Clear entire LCD screen.
    Light_on CON 14
    CR CON 13
    N9600 CON $4054
    'variáveis 1-wire
    'crc VAR Word
    'romdata1 VAR Byte(8)
    'outras variaveis
    ROMDATA VAR Byte(32)
    Ink_remain VAR Word
    digi_ink_remain VAR Word
    contador var word
    StatusReg VAR Word
    crc_lido var word
    crc_gravado var word
    SMT_lida VAR Word
    DGC_lido VAR Word
    pin var byte
    pin_digichip var byte
    idx VAR Byte
    blank VAR Byte
    ink_end VAR Byte
    St_count VAR Byte(8)
    cor VAR Word
    factor VAR Word
    idx1 VAR Byte
    ink_flag_status var bit
    ds2431_flag var bit
    AppReg1 var byte
    ee var byte
    st_count(0)=0
    st_count(1)=0
    st_count(2)=0
    st_count(3)=0
    st_count(4)=0
    st_count(5)=0
    st_count(6)=0
    st_count(7)=0
    low portA
    low portB
    LOW 12
    GOSUB LCD_light_ON
    Serout2 12,N9600,["V1 18F1320 9/12/06"]
    GOSUB lcd_cr
    pause 2000
    ' goto loop
    boot_init:
    FOR cor =1 TO 4
    ink_flag_status=0
    gosub St_continua
    next
    st_count(0)=0
    st_count(1)=0
    st_count(2)=0
    st_count(3)=0
    st_count(4)=0
    st_count(5)=0
    st_count(6)=0
    st_count(7)=0
    gosub identifica_cor
    Loop: 'inicio do loop para leitura de ink_remain
    FOR cor =1 TO 4
    ink_flag_status=0
    PAUSE 1500
    GOSUB init_lcd
    Serout2 12,N9600, ["COR ",dec1 cor]
    GOSUB Lcd_cr
    GOSUB Ler_Readscratch
    GOSUB ink_flag 'detecta se RB2(ink flag) está sem tinta
    GOSUB Lcd_cr
    'GOSUB Ink_Remain_read
    avanca0:
    NEXT
    GOTO loop
    Read_ROM: '33 le o rom id do ds2430
    gosub cor_pin_rb1
    'if cor=1 then pin=11
    'if cor=2 then pin=10
    'if cor=3 then pin=9
    'if cor=4 then pin=8
    ' gosub init_lcd
    OWOUT pin,OW_FERst,[readrom] ' send Read ROM command
    ' PAUSE 35
    OWIN pin,OW_BERst,[ STR romData\8] ' le os oito bytes do rom id e grava na variavel romdata
    for idx =0 to 7
    serout2 12,N9600,[hex2 romdata(idx)]
    next
    GOSUB Lcd_cr
    Read_Memory:: 'F0 'le a memoria da EEprom na totalidade
    'CC
    gosub init_lcd
    OWOUT porta.3,OW_FERst,[$CC,$F0,$00] ' send Read ROM command
    PAUSE 15
    OWIN porta.3,OW_BERst,[ STR romData\32]
    FOR idx = 0 TO 31
    pause 5
    serout2 12,N9600, [HEX2 romData(idx)] ' show ID, serial num, CRC
    NEXT
    identifica_cor:
    gosub init_lcd
    FOR cor =1 TO 4
    gosub init_lcd
    gosub cor_pin_rb1
    OWOUT pin,OW_FERst,[$CC,$F0,$00] ' send Read ROM command
    PAUSE 100
    OWIN pin,OW_BERst,[ STR romData\32]
    pause 50
    FOR idx = 0 TO 31
    pause 5
    NEXT
    if romdata(01)=1 then serout2 12,N9600, [" CYAN"]
    if romdata(01)=2 then serout2 12,N9600, [" MAGENTA"]
    if romdata(01)=3 then serout2 12,N9600, [" YELLOW"]
    if romdata(01)=4 then serout2 12,N9600, [" BLACK"]
    if romdata(01)=6 then serout2 12,N9600, [" LMagenta"]
    if romdata(01)=5 then serout2 12,N9600, [" LCyan"]
    if romdata(01)>6 then serout2 12,N9600, [" ERRO"]
    next
    cor_pin_rb1:
    if cor=1 then pin=9 '
    if cor=2 then pin=8
    if cor=3 then pin=3
    if cor=4 then pin=2
    Ler_Readscratch:
    gosub cor_pin_rb1
    ' gosub init_lcd
    serout2 12,N9600, ["EE TintOr Cont" ]
    pause 15
    GOSUB Lcd_cr
    OWOUT pin,OW_FERst,[$CC,$AA,$00] ' send Read readscratch
    PAUSE 50
    OWIN pin,OW_BERst,[ STR romData\5]
    ee=romdata(0)
    ink_remain.byte1 = romdata(1)
    ink_remain.byte0 = romdata(2)
    contador.BYTE1 = romdata(3)
    contador.BYTE0 = romdata(4)
    serout2 12,N9600, [HEX2 ee," ",dec3 ink_remain/10, " ", dec4 contador/10]
    GOSUB Lcd_cr
    sometimes RA.0 give just FFFF... from routine Identifica_cor!
    What can be the cause?
    joao
    OK, you're a BS2 converted now
    PIN is not valid in PBP. To write to a specific I/O you must use the according name. Something like PORTA.0=1
    You can also use an alias
    LED1 var PORTA.0
    then later you use LED1=1
    You can also use HIGH and LOW with a pin#
    SEROUT and some other MAY work using a pin # but it's really not readable later ( let's say HIGH 8 ... what the hell is 8? yeah it's PORTA.0... few minutes later ) I suggest you use the I/O name or an alias to the I/O
    i can't confirm it will work as is, usually we use
    ROMDATA VAR Byte[32]
    Just change your parenthesis to square bracket. Same thing when you want to read/write to a specific Array
    ROMDATA[0]=123
    As you're using a PIC with an internal USART, there's no need to use SEROUT/SEROUT2, use HSEROUT instead if your hardware permit. Better IMHO
    HTH
