newbie with serial com question...
Results 1 to 6 of 6
    Dec 2005
    Salt Lake City, Ut, USA
    Question Sorry I'm so late to respond...another simple? question
    Thank you guys for the responses you gave me. I'm sorry I couldn't thank you sooner...been busy trying picbasic. I've got one more question, that I hope one of you can help me with. I can't seem to get my head around how the pic can take in three bytes in a row from the PC...
    (ie: mscomm1.output = 9 + 22 + 1)
    and know that the first byte is the address, the second is the output, and the third is the state? I think I'm just over-thinking this. Can one of you gentleman help me understand this?
    Do I do it like this:
    serpin VAR porta.0
    address VAR b3
    output VAR b4
    stat VAR b5
    If b3 = PORTB then
    SERIN serpin,N2400,address,output,stat..........
    is serpin b1
    is N2400 b2
    is address b3
    is output b4
    is stat b5
    Am I thinking correctly, or am I way off base?
    Thanks for letting me bend your ear...
    Chris
    Feb 2005
    Kolkata-India
    Default When you can't afford to loose a byte.
    Most of the time your PIC should be listening to the available data. Use some sort of acknowledge when it receives a valid packet. You can try respond through the control lines of the RS232 ports.
    Other possibilities are using the PIC's hardware USART. The hardware USART normally has a two byte buffer and generates an interrupt when a byte is received.
    By using Darrel's Instant Interrupt implementing it should not be a big deal.
    All you need to do it get the bytes in a ring array or FIFO for processing later. Use some sort of unique Header and Terminator in your packet send by the PC. If your are using a FIFO in your main program loop go on hunting for the terminator(the last byte received). When found you can check your FIFO's deepest location (since the data packet length is fixed) for a valid header. If found then anything between your header and terminator is your data packet.
    Sougata
  1. Wireless serial communication question
    By Ahmadabuomar in forum Serial
    Last Post: - 21st December 2009, 04:49
  2. serial LCD/SLCD question
    By MatthewM in forum mel PIC BASIC Pro
    Last Post: - 18th May 2009, 15:56
  3. Serial Question + General Review
    By Freman in forum General
    Last Post: - 20th June 2008, 23:27
  4. AN Question for "word" variable read The serial port
    By redfoen in forum mel PIC BASIC Pro
    Last Post: - 14th December 2007, 18:39
  5. Simple question, I hope? (Serial control, 16F84A)
    Last Post: - 31st December 2005, 20:47
