Changing declared variables names on the fly
Results 1 to 16 of 16
    jessey's Avatar
    jessey Guest
    Default Changing declared variables names on the fly
    Hello,
    This is probably a dumb question but is there a way using PBP to have a variable with-in a declared variable name? Its a little hard to explain exactly what I mean but it would be sort of like this:
    You want to print a variable name to your Lcd so you print:
    LCDOUT $FE,1,"On_Timer_Hour",DEC M," "
    the On_Timer_Hour would be your declared variable and the variable with-in it would be the M variable. Setting the M variable before the print to the Lcd (or in your code) would change the variable name displayed to the Lcd. So the variable On_Timer_Hour could be On_Timer_Hour1, On_Timer_Hour2, On_Timer_Hour3 ect. ect.. It would be great if I could implement that concept in my code. Wishful thinking?
    Why I'm asking is: I'm writing a timer program where the user can programme 10 different On and Off times that repeats every 24 hours using Darrels ELASPED.PBP. I have in excess of 100 variables that all have a numerical value at the end of the variable name. If it is possible to use a variable with-in a declared variable name then it would save a lot of code space.
    In each of the 10 timer sections (I'd like to have more if I can gain more code space) I have intermediate dummy variables that all have to be set then re-set to implement my code. It would be great if I could just change one M variable that would change them all. There's a lot I don't understand about programming, like array variables with a variable index or other concepts that could make writing code more efficient. What is the concept of a variable index? Would that have anything to with what I'm trying to accomplish here?
    Is it possible or just wishful thinking.
    jessey
    Jan 2006
    Istanbul
    Hi Jessey,
    It seems you really need to use array.
    Since you need 10 different ON times and 10 different OFF times, 20 variables would give you a lot of headache if not using array.
    But, if I got it right, then a simple code as below could be the idea for you, may be.
    EEPROM 1,[1,2,3,4,5,6,7,8,9,10,101,102,103,104,105,106,107,108,109,110]
    'Say these are your stored alarm time(s).
    '1 to 10    : ON time
    '101 to 110 : OFF time
    OnTime  var byte
    OffTime var byte
    Index   var byte
    Hour    var byte
    Alarm   var PORTB.0  'A relay is connected here to wake you up!
    'Hour variable gets its value from RTC routine somewhere in the code....
    Start:
        FOR Index = 1 to 10
            READ Index , OnTime       'Read stored ON  time.
            READ Index +100, OffTime  'Read stored OFF time.
            IF Hour = Ontime  THEN ALARM = 1 'Check if there is a match with the current time. If yes, turn ON the relay.
            IF Hour = Offtime THEN Alarm = 0 'Check if there is a match with the current time. If yes, turn OFF the relay.
        NEXT Index
    GOTO Start
    Hour variable is just an example. Assuming you get your hour variable somewhere in the code. It could be the minute, the second, the day, year etc... or all of them together.
    Say you stored the "Alarm ON" time in the eeprom location 1. Then its corresponding "Alarm OFF" time should be stored in a sequenced number, for example +100, 101.
    This way you can have an array to make more and more variables to match. Use a simple code as above first to start understanding the idea.
    jessey's Avatar
    jessey Guest
    Default How do I READ & WRITE to the EEPROM 1, [1,2,3......]
    Hello Sayzer,
    Thanks for answering my question. Forgive my ignorance but I'm not familiar with your code example or how to implement it. I am familiar with how to read & write to the eeprom, for a byte variable I use
    EEPROMData0 VAR BYTE
    U VAR EEPROMData0
    READ 0, EEPROMData0
    to write I use:
    EEPROMData0 = U
    Write 0, EEPROMData0
    then for a word variable I use
    EEPROMData1 VAR WORD
    V VAR EEPROMData1
    Read 1, EEPROMData1.byte0
    Read 2, EEPROMData1.byte1
    to write I use:
    Write 1, EEPROMData1.byte0
    Write 2, EEPROMData1.byte1
    In your example code I don't know how I would write to locations 1 to 10 and 101 to 110 of the eeprom address location 1? Could you please explain the concept as I'm not sure how to do that. I can sorta understand your Index loop but I don't see any relationship between the Index variable and the EEPROM 1, [1,2,3......] statement? I've seen the EEPROM 1, [1,2,3......] statements in some of the code examples in the archives but I just don't understand the concept.
    Could you educate me about how this works?
    jessey
    Jan 2006
    Istanbul
    Quote Originally Posted by jessey
    ...locations 1 to 10 and 101 to 110 of the eeprom address location 1?..
    jessey
    1, 10 or 101 or 110 these are all already EEPROM locations. So there is no access to "10 of location 1". 10 is the location.
    For the index example,
    when index=1, take a look at the following code.
    READ Index , OnTime
    READ Index+100, OffTime
    Lest put "1" in index variable and re-write these two lines again.
    READ 1, OnTime
    READ 1 + 100, OffTime
    Now, the third time, this will become as follows.
    READ 1, OnTime
    READ 101, OffTime
    With these two lines, you will read EEPROM location 1 and store the location content in Ontime variable. And, read EEPROM location 101 and store the location content into OffTime variable.
    Now, you can take a look at FOR loop above and think about incrementing index variable. When index variable changes, the eeprom location that we read also changes.
    Any question there?
    jessey's Avatar
    jessey Guest
    Default How do I write to the eeprom locations?
    Hi Sayzer,
    Thanks for your explanation about the For-Next loop, I think I can grasp the concept of the Index For-Next loop now but what I don't understand is how do I write the values to the different eeprom locations. I added some push buttons to your code to try and increase and decrease the OnTime & OffTime variables and the Hour variable in an attempt to flash an Led but can't get it to work. Could you please help me to understand how to write to the different eeprom locations?
    jessey
    'Pic18f452-20/P
    Increase_OnTime_Push_Button VAR PORTD.2    '(pin 21)  2nd
    Decrease_OnTime_Push_Button var PORTB.0    '(pin 33)  3rd
    Increase_OffTime_Push_Button var PORTB.1   '(pin 34)  4th
    Decrease_OffTime_Push_Button var PORTB.2   '(pin 20)  5th
    Change_On_Off_Time_Push_Button VAR PORTD.1 '(pin 35)  6th
    Led VAR PORTA.1                            '(pin 3)
    Buzzer VAR PORTC.2                         '(pin 17)
    OnTime  var byte
    OffTime var byte
    Index   var byte
    Hour    var byte
    HOUR = 0
    Is_Pressed con 0
    Is_Not_Pressed con 1
    GOTO MainLoop
    Change_On_Off_Time:
        PWM Buzzer,250,1
        WHILE Change_On_Off_Time_Push_Button = Is_Pressed : PAUSE 100 : WEND
    Loop:
        IF Increase_OnTime_Push_Button = Is_Pressed THEN
           OnTime = OnTime + 1 : PWM Buzzer,250,1
           WRITE 1, OnTime
        IF Decrease_OnTime_Push_Button = Is_Pressed THEN
           OnTime = OnTime - 1 : PWM Buzzer,250,1
           WRITE 1, OnTime
        IF Increase_OffTime_Push_Button = Is_Pressed THEN
           OffTime = OffTime + 1 : PWM Buzzer,250,1
           WRITE 101, OffTime
        IF Decrease_OffTime_Push_Button = Is_Pressed THEN
           OffTime = OffTime - 1 : PWM Buzzer,250,1
           WRITE 101, OffTime
        IF Change_On_Off_Time_Push_Button = Is_Pressed THEN
          PWM Buzzer,250,1
           LCDOUT $fe,1,"OnTime  = ",dec Ontime
        LCDOUT $fe, $c0,"OffTime = ",dec OffTime
        PAUSE 100
    goto Loop
    MainLoop:
        IF Change_On_Off_Time_Push_Button = Is_Pressed THEN GOSUB Change_On_Off_Time
       'Hour variable gets its value here......
           Hour = Hour + 1 : PWM Buzzer,250,1
           Hour = Hour - 1 : PWM Buzzer,250,1
           LCDOUT $fe,1,"Hr=",dec Hour," OnTime=",dec Ontime
        PAUSE 100
        FOR Index = 1 to 10
            READ Index , OnTime            ' Read stored ON  time.
            READ Index +100, OffTime       ' Read stored OFF time.
            IF Hour = Ontime  THEN Led = 1 ' If yes, turn ON the relay.
            IF Hour = Offtime THEN Led = 0 ' If yes, turn OFF the relay.
        NEXT Index
    GOTO MainLoop
    Red face
    WRITE will work at run-time
    EEPROM or DATA will work at Programming time
    DATA @101,10 will write 10 at address 101 at programming time
    WRITE 101,10 will write 10 at adress 101 at run time
    i will read-back the whole post here, but it think you already understand the concept... OR i'm too drunk ... no way!
  1. changing osc on the fly
    By viewgsm in forum mel PIC BASIC Pro
    Last Post: - 6th February 2010, 16:13
  2. Mode changing on the fly
    By Angus Anderson in forum GSM
    Last Post: - 28th November 2006, 09:58
  3. edit names of variables
    By mischl in forum mel PIC BASIC Pro
    Last Post: - 13th January 2005, 22:00
