16f88 can't get lcd to work
Results 1 to 13 of 13
    try....
    PAUSE 2000
    Lcdout $fe, 1, "Hello" ' Display Hello
    Pause 2000
    LCDOUT $FE,1,"John"
    Spin: goto Spin
    if it doesn't work, you may need to double check your hardware, make sure your programmer program the config fuses, and make sure your MCLR pin is not floating.
    usual... 0.1uF cap close to the PIC, LCD R/W pin to GND and so on
    In general the HS_OSC fuse may work with 4MHZ crystal but also try with XT_OSC to see if it make any difference.
    Jun 2006
    try this
        PAUSE 500
    loop:
        Lcdout $fe, 1,"Hello" ' Display Hello
        Pause 2000
        Lcdout $fe, 1,"John"
        Pause 2000
        goto loop
    Default Give This A Try
    Hi John,
    Try this, I couldn't get the config fuses right for mpasm, but I was able to get them right for the default assembler. it should work keyword should.
    JS
    @ DEVICE MCLR_OFF, XT_OSC, WDT_OFF, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF
    DEFINE OSC 4 ' XT osc
    DEFINE LCD_DREG PORTB
    DEFINE LCD_DBIT 4
    DEFINE LCD_RSREG PORTB
    DEFINE LCD_RSBIT 3
    DEFINE LCD_EREG PORTB
    DEFINE LCD_EBIT 2
    DEFINE LCD_BITS 4
    ' Set number of lines on LCD
    DEFINE LCD_LINES 2
    DEFINE LCD_COMMANDUS 2000
    ' Set data delay time in us
    DEFINE LCD_DATAUS 100
    TRISB=%00000000                            ' all portb to output
    TRISA=%00000000                            ' all porta to output
    ADCON1 = 7 ' or ADCON1 = %00000111 'Disable A/D converter
    ANSEL=%00000000 ' set all analog pins to digital
    CMCON=7
    main
    pause 2000
    LCDOUT $FE,1,"John"
    Joe
    The MPASM config fuses are in the p16f88.inc file in the Microchip\MPASM suite folder
    _CONFIG1                    EQU     H'2007'
    _CONFIG2                    EQU     H'2008'
    ;Configuration Byte 1 Options
    _CP_ALL                      EQU     H'1FFF'
    _CP_OFF	                     EQU     H'3FFF'
    _CCP1_RB0		    		 EQU     H'3FFF'
    _CCP1_RB3                    EQU     H'2FFF'
    _DEBUG_OFF                   EQU     H'3FFF'
    _DEBUG_ON                    EQU     H'37FF'
    _WRT_PROTECT_OFF             EQU     H'3FFF'	;No program memory write protection
    _WRT_PROTECT_256             EQU     H'3DFF'	;First 256 program memory protected
    _WRT_PROTECT_2048            EQU     H'3BFF'	;First 2048 program memory protected
    _WRT_PROTECT_ALL             EQU     H'39FF'	;All of program memory protected
    _CPD_ON                      EQU     H'3EFF'
    _CPD_OFF                     EQU     H'3FFF'
    _LVP_ON                      EQU     H'3FFF'
    _LVP_OFF                     EQU     H'3F7F'
    _BODEN_ON                    EQU     H'3FFF'
    _BODEN_OFF                   EQU     H'3FBF'
    _MCLR_ON		   		     EQU     H'3FFF'
    _MCLR_OFF                    EQU     H'3FDF'
    _PWRTE_OFF                   EQU     H'3FFF'
    _PWRTE_ON                    EQU     H'3FF7'
    _WDT_ON                      EQU     H'3FFF'
    _WDT_OFF                     EQU     H'3FFB'
    _EXTRC_CLKOUT		    	 EQU     H'3FFF'
    _EXTRC_IO		    		 EQU     H'3FFE'
    _INTRC_CLKOUT                EQU     H'3FFD'
    _INTRC_IO		    		 EQU     H'3FFC'
    _EXTCLK			    		 EQU     H'3FEF'
    _HS_OSC                      EQU     H'3FEE'
    _XT_OSC                      EQU     H'3FED'
    _LP_OSC                      EQU     H'3FEC'
    ;Configuration Byte 2 Options
    _IESO_ON                     EQU     H'3FFF'
    _IESO_OFF                    EQU     H'3FFD'
    _FCMEN_ON                    EQU     H'3FFF'
    _FCMEN_OFF                   EQU     H'3FFE'
    AND NEVER EVER END A PROGRAM WITH A SINGLE END STATEMENT... use STOP OR an endless loop
    Here we don't know if the user use an external or want to use the internal OSC...
    Default you right boss!
    Quote Originally Posted by mister_e
    Joe . . .
    AND NEVER EVER END A PROGRAM WITH A SINGLE <h1>END</h1> STATEMENT... use STOP OR an endless loop
    Sorry about that mister_e, it got by me on the fourth paste, I had installed a goto main and then did a repaste and, oops left it out. As for mpasm config fuses . . . I kept getting errors using this format
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_ON & _PWRTE_ON & _MCLRE_OFF & _LVP_OFF & _BODEN_ON
    but not this exact code. I have edited above post.
    JS
    Yeah F88 is a bit like some 18F, try something around those bellow
        '    Pic Configuration
        '    Program Configuration Register 1
        @	__CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_ON & _MCLR_OFF & _PWRTE_ON & _WDT_OFF & _INTRC_IO
        '    Program Configuration Register 2
        @   __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
    Default 16f88
    Hi Mister_e,
    The 16F88 seems to be extra labor intensive and not suitable for newbies, as it has so many registers that require you to set and other little quirks, there are several open posts this month by people (like myself) who are a little short on experience, that are having trouble with this device. I think they would do better with a 16F628a / 648a or 16F876 / 877 etc. At least until they get their sealegs.
  1. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  2. Need help with LCD number display.
  3. Why doesn't my code for 18f452 work on 18f252?
    By senojlr in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2005, 03:42
  4. Can't get LCD to work with 16F88
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 10th September 2004, 12:05
  5. 4 line LCD with 16F88
    By anj in forum mel PIC BASIC Pro
    Last Post: - 7th February 2004, 10:06
