Steve,
Well it must be either something querky with either the programming software or the 18F series of chips (or just the 18F2550)
I tried repeating some of the things here but using a 16F873A PIC (just happened to have a couple in my hobby box - no other reason) I compiled the following code (edited version of your test code)
It compiled with out error and loaded without error (using either application, Winpic or PICpgm). This was using the default INC files I also tried my original code (in post 1 I think) and that too loaded fine. But try as I might, even though the programmer, both software and hardware claim to support 18F2550's I can't get it to work with this PIC.Code:ADCON1=$0F TRISB=%00000000 'set PORTB as all output PORTB=0 ByteA var byte main: for bytea=0 to 7 PORTB=DCD BYTEA PAUSE 250 NEXT PORTB=255 PAUSE 250 goto main
I've yet to breadboard and test the PIC - and I need to swatt up on the datasheet to see what this 16F873A offers, but as I don't need anything too fancy I'm sure it will do just fine (assuming I can get the hardware running)
