Advice please - Warning message
Results 1 to 40 of 51
Threaded View
  1. #40
    malc-c's Avatar
    malc-c Guest
    Steve,
    I've pointed the programmer to the correct path of the DEV files and it made no difference. ( as you can see no message saying it can't find the file)
    Programming...
    Erasing ("bulk" or "chip") ...
    Programming CODE, 0x000000..0x0000B4
    Verifying CODE, 0x000000..0x0000B4
    Verifying 0x000000..0x0000B4
    Programming CONFIG, 0x300000..0x300006
    Verifying CONFIG, 0x300000..0x300006
    Verifying 0x300000..0x300006
    Verify Error: 300000: read 000000, wanted 0030C0, mask 00FFFF ==> diff=0030C0
    Verify Error: 300002: read 000E3E, wanted 00CEFE, mask 00FFFF ==> diff=00C0C0
    Verify Error: 300004: read 008000, wanted 00F8FF, mask 00FFFF ==> diff=0078FF
    Verify Error: 300006: read 0000A1, wanted 00FFBB, mask 00FFFF ==> diff=00FF1A
    ERROR: Programming FAILED !
    I also typed in the "30C0 and CEFE" into the first two config memory locations and tryed programming that - it errored as before.
    I've had this programmer working as I've used it to program USB RC-Joystick file, but I've juts tried that code and it too errored. The only difference is I'm now using XP Home and SP2, but I'm sure that would have no bearing on this issue ?
    Malc
    EDIT - oh and this was the third and last 18F2550 PIC I had 0 fresh out of the tube !
  1. PIC16F690 PBP boundary crossing warning message
    Last Post: - 9th May 2008, 11:17
  2. Micro Code Studio - Warning message
    Last Post: - 17th November 2006, 21:17
  3. MicroCode Studio Boundary Warning Message
    By coyotegd in forum mel PIC BASIC Pro
    Last Post: - 16th March 2006, 09:13
  4. Message String Table using Readcode
    By mytekcontrols in forum Code Examples
    Last Post: - 10th July 2005, 23:17
  5. warning message
    By pic beginner in forum mel PIC BASIC Pro
    Last Post: - 23rd July 2004, 02:53
