Startup power higher than while program running - why?
Results 1 to 14 of 14
    SWITZERLAND (french speaking)
    Default Okay, I'll init it LOW
    Okay, I'll init it LOW.
    It was now clear to me.
    Checking this out now...
    You're right - now it works fine.
    Actually, I noticed that all PORTBs are driven HIGH for one second when I power-up the circuit. I initilize them to LOW but this happens after the register setting.
    I don't think it would make sense to set the PORTBs LOW before the registers are set, does it?
    Roger
    Feb 2005
    Kolkata-India
    Default Try this
    Could you please insert the following lines in your register settings:
    SSPCON.5   = 0                  ' DISABLE THE SYNC.SERIAL.PORT AND USE AS I/O
    TRISB      = %11000000
    PORTB      = 0                  ' Init PORTB to low
    Portb.5 is shared with the onboard Synchronous Serial Port. Turning off bit 5 of the SSPCON registers turns off this peripheral and configures it as general I/O.
    Sougata
    Default Default register settings
    Sougata,
    I think my SSPCON register is already set but, just to make sure, am I right to say that in the PIC's datasheet, the register settings have default values I can read like here "R/W-0" and it would mean that the bit is set to 0?
    REGISTER 10-2: SSPCON: SYNCHRONOUS SERIAL PORT CONTROL REGISTER (ADDRESS 14h)
    R/W-0 R/W-0 R/W-0   R/W-0 R/W-0 R/W-0 R/W-0 R/W-0
    WCOL  SSPOV SSPEN(1)CKP   SSPM3 SSPM2 SSPM1 SSPM0
    bit 7                                       bit 0
    Roger
    Feb 2005
    Kolkata-India
    Default You are right
    The default when the PIC starts is SSPCON turned off. But you mentioned that your portb is keeping high for sometime from start. There has to be a logical reason why. I do not have a 16F88 lying so cannot give it a try myself. May be I should give a closer look to your code.
    Sougata
    Sougata,
    Thank you for confirmation.
    As said in a previous post, I have solved the problem by putting a 1µF cap in serie with the BUZZER.
    Roger
  1. Battery powered applications
    Last Post: - 22nd June 2009, 07:12
  2. Pic getting part power from Analog Port
    By ShaneMichael in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2009, 10:34
  3. Making Program Code Space your playground...
  4. Replies: 4
    Last Post: - 16th May 2008, 14:35
  5. Program returns to beginning at interupt
    By BGreen in forum mel PIC BASIC Pro
    Last Post: - 25th April 2005, 11:20
