10 pins total at the connector, only 5 pins used, not an xlr type, in fact not even pins and sockets. They're almost more like a BGA chip and the outside shell of the connector does the job of applying the pressure by latching them together. I wish I had one here at the house so I could get a picture.Originally Posted by mister_e
In forgot to mention in my last post, on the few headsets that I've gotten in that don't have that circuit I described earlier (and they don't work either!), on those 5 pins at the connector, I've got 1 to the braided shield (ground), 2 to the mike, and 2 to the earphones.
No company name or anything on them anywhere to be found, a couple of model numbers on the various plugs and one on the mike and earpiece. The books say to order a new one from Roanwell, which I called and doesn't sell them anymore (in fact they don't know anything about them).
I've got a functional station to test them out at, problem is it's about 12 miles away which is why I kinda want to rebuild this tester for the shop. I've probed it. Nothing spectacular. That same ground pin on the headsets, goes to the chassis of the box. If I touch 5v across the mike contacts at my station, I get clicks in earpieces at another station. If I touch 5v across the earpiece contacts at my station, I get light clicks in the mike at the other station, which is what I would expect. So, that tells me that I've got the right pins for the right job.
Maybe your beltpack and my switch/box/circuit board might have something in common. Next week, I'll try to reverse engineer that board and see what I come with. That'll probably tell me everything I need to know.
JDG
