How to drop from 6V to 5V a "clean" way?
Results 1 to 21 of 21
    Italy
    Quote Originally Posted by BobP View Post
    I just looked at the maximum ratings for the 18F2525 and it says it can take a max of 7.5 volts!
    So running a 2525 from 4 x 1.5v cells should be ok. Check the datasheet for the PIC you are using.
    Hi Bob,
    The voltage 7.5V is not the maximum operating voltage of the chip.
    The 7.5V visible in the "Absolute Maximum Ratings" page 323, is
    the voltage where you can go without physical damage to the chip.
    The PIC18F2525 will operate reliable only when the voltage is between
    4.2V and 5.5V.
    This note is visible on page 323:
    NOTICE: Stresses above those listed under “Absolute Maximum Ratings” may cause permanent
    damage to the device. This is a stress rating only and functional operation of the device
    at those or any other conditions above those indicated in the operation listings of this
    specification is not implied. Exposure to maximum rating conditions for extended periods
    may affect device reliability.
    See the datasheet page 326, parameter No. D001 for the operating voltage.
    Datasheet:
    http://ww1.microchip.com/downloads/e...Doc/39626b.pdf
    Best regards,
    Luciano
    Mar 2004
    UK-Midlands
    Many thanks Luciano, I thought it seemed a bit high but as usual I get interupted with phones etc. before reading it properly.
    Bob
    Mar 2006
    Hyderabad (India)
    If possible, add another call and use 7805. but after an hour of use the voltahge will fall below the I/O differental of 2.5V.then the problem comes.
    As many devices work upto 3.3V, why not consider using 3 cells at 4.5V?
    Sarma
  1. Generating 5v from 4 batteries
    By BobP in forum Off Topic
    Last Post: - 27th December 2009, 10:46
  2. 6V to 5V
    By Fisher in forum Schematics
    Last Post: - 11th August 2008, 18:31
  3. 1.5 v to 3v and 5v? Really confused.
    By kevj in forum Schematics
    Last Post: - 17th October 2007, 15:16
  4. 5v and 7v on same board - question
    By mark.oswald in forum Schematics
    Last Post: - 29th July 2007, 00:03
  5. Replies: 5
    Last Post: - 23rd February 2005, 18:35
