Is there a label restriction
Results 1 to 6 of 6
    May 2006
    Here is part of my code. This is for communication from one micro to another. I can't seem to find it. Thanks.
    INITIATE_COMM VAR PORTA.2
    SETUP_SERIAL_RECEIVE:
    PAUSe 10
    GOSUB SERIAL_REQUEST
    TRISC = %01000000
    PAUSE 10
    LISTEN_RECEIVE:
    BUTTON INITIATE_COMM, 1, 255, 0, C7, 0, RX -line 258, ID not Label
    PAUSE 10
    GOTO LISTEN_RECEIVE
    SERIAL_REQUEST:
    ' request variable values
    OUTPUT_DATA_REQUEST = 1 ' request other chip to communicate
    BUTTON INITIATE_COMM, 1, 255, 0, C7, 1, RETURN -line 265, bad exp
    PAUSE 10
    GOTO SERIAL_REQUEST
    RX:
    OUTPUT_DATA_REQUEST = 0 ' turn off pin to send data
    PAUSE 10
    SERIN2 SERIAL_INPUT, 600, [WAIT("A"), BIN MODE] - line 272, bad exp
    SETUP_SERIAL_TRANSMIT:
    PAUSe 10
    TRISC = %01000000
    PAUSE 10
    LISTEN_XMIT:
    BUTTON INITIATE_COMM, 1, 255, 0, C7, 0, TRANSMIT_DATA - line 280, bad ex
    PAUSE 10
    GOTO LISTEN_XMIT -line 282, ID not a label
    TRANSMIT_DATA:
    PAUSE 10
    Errors
    ERROR Line 258: ID RX is not a label. (16F687 Controller w LCD v01.pbp)
    ERROR Line 265: Bad expression. (16F687 Controller w LCD v01.pbp)
    ERROR Line 272: Bad expression. (16F687 Controller w LCD v01.pbp)
    ERROR Line 280: Bad expression. (16F687 Controller w LCD v01.pbp)
    ERROR Line 282: ID LISTEN_XMIT is not a LABEL. (16F687 Controller w LCD v01.pbp)
    it will be hard without the whole variable definition but...
    how you defined C7 and RX?
    RETURN is a reserved word.. you MUST use a label name where to jump. On this label you will use a return.
    Shouldn't be a problem... and you know that 600 is not 600 bauds right?
    May 2006
    C7 VAR BYTE
    Rx should be used as label and not used anywhere else.
    I thought maybe I could use RETURN because I am doing a gosub to to jump into sub routine and then I want to exit that and return to what i was doing.
    I decided not to try use the one piece of code as a sub-routine and fixed this by just with putting the code in twice. The problem disappeared. My program is huge and I was trying to be extra efficient. I think i am going to have to just go with a micro that has a larger memory. I am using a LCD with this application communicating serially. The code seems to be piling up quickly.
    May 2006
    I compiled my code for the 16F687 and saw that it came up to 2042 words and I am still not done writing. I thought I would migrate up to the 16F689 and the code size jumps to 2571 words. Is this because it now needs to go back and forth between memory pages.
  1. PBP projects for R/C models
    By malc-c in forum Code Examples
    Last Post: - 21st October 2016, 12:56
  2. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 22:14
  3. I2C optional label question
    By F1CHF in forum mel PIC BASIC Pro
    Last Post: - 13th July 2009, 17:17
  4. Can a line label be aliased to a VAR?
    By LinkMTech in forum mel PIC BASIC Pro
    Last Post: - 22nd December 2008, 22:29
  5. 18F452 "Unknown Processor" errors
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 27th April 2006, 03:56
