spi and shiftin/out
Results 1 to 3 of 3
    scorpion's Avatar
    scorpion Guest
    Default spi and shiftin/out
    Hi Im using a qt511 touch sensor from qprox.com and im having problems communicating with it.
    basically i cant read and im assuming that i cant write to it either.
    here are some code snipits.
    include "modedefs.bas"
    define shift_pauseus 40
    Define OSC 20 '20Mhz HS xtal
    sdo var porta.0
    sdi var porta.1
    sclk var porta.2
    drdy var porta.3
    ss var porta.4
    det var porta.5
    TRISA = %101010
    TRISB = %00000001
    TRISC = %00110000
    ADCON1 = %00001111
    ccp1con = 0
    ccp2con = 0
    high sclk
    high led1
    high led2
    high led3
    'allow touch sensor to calibrate
    high ss
    for i = 1 to 500
    pause 1
    USBService
    next i
    calibratesensor:
    if drdy = 1 then goto MainLoop
    pause 1
    goto calibratesensor
    MainLoop:
    if sensorprepped = 0 then gosub sensorprep
    if drdy = 1 then
    if driftcntr > 100 then
    gosub driftcomp
    driftcntr = 0
    gosub gettouch
    led1 = ~ touched
    GetTouch:
    low ss
    pauseus 15
    shiftin sdi, sclk, 6, [touchin]
    toucher = touchin & %10000000
    if toucher = 0 then
    touched = FALSE
    touched = TRUE
    sensorprepped = 0
    driftcomp:
    low ss
    pauseus 15
    shiftout sdo,sclk, 5, [3]
    sensorprepped = 0
    sensorprep:
    high ss
    pauseus 15
    low ss
    pauseus 2
    high ss
    sensorprepped = 1
    driftcntr = driftcntr + 1
    PS. no oscilloscope just 3 onboard leds.......
    sorry thats so long.
    if anyone can spot what im doing wrong i would really appreciate it.
    tia
    scorpion's Avatar
    scorpion Guest
    Default please?
    anyone have any help to offer?
    Im really stuck here
    scorpion's Avatar
    scorpion Guest
    Default anyone?
    if i can provide any more info i would be glad to... can anyone help?
  1. Faster Clock Speed for Shiftin/out?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 15th December 2005, 03:15
