Serout2/serin2 Pbp Problem
Results 1 to 4 of 4
    Dec 2006
    WADSWORTH OHIO USA
    Question Serout2/serin2 Pbp Problem
    GREETINGS ALL!!
    AS USUAL I'M IN SEARCH OF THE OBVIOUS.
    I'M USING 2 PIC16F870'S AND PBP.
    IT CAN NOT BE THIS DIFFICULT TO TRANSFER A FOUR DIGIT NO. ie 1234
    FROM ONE PIC TO ANOTHER WITH ALL THE MAGIC PBP HAS.
    I SEEM TO BE MISSING THE INCANTATION, AND AM ASKING IF SOMEONE
    COULD RECITE IT FOR ME. FOLLOWING IS THE CODE.
    'PIC7 SENDING
    DEFINE OSC 20 'DEFINE OSCILLATOR
    DEFINE SER2_BITS 8
    AMP VAR WORD 'DEFINE VARIABLES
    AMPS VAR WORD
    ARX VAR BYTE[4]
    TDIR VAR BYTE
    CDIR VAR BYTE
    SDIR VAR BYTE
    STR1 VAR BYTE
    TIME VAR WORD
    TIMES VAR WORD
    ATEST VAR WORD
    TTEST VAR WORD
    TRX VAR BYTE[4]
    C VAR BYTE
    'EQUATES SECTION
    TRISA = %00110001 'SET PORTS I/O
    TRISB = %10011101
    TRISC = %00001111
    ADCON0 = %00000000
    ADCON1 = %00000011 'PORTA ALL DIGITAL
    TIME = 1234 'SET FOR TEST
    AMP=5678
    'MISC CODE xxxx OMITTED FOR BREVITY
    GOSUB SND6
    SND6: 'SEND DIGITS TO PIC6
    HIGH PORTB.2
    PAUSEUS 40
    Serout2 PORTB.5 \PORTB.6,84,[TIME,AMP]
    LOW PORTB.2
    'PIC6 RECIEVE
    DEFINE SER2_BITS 8
    AS VAR WORD 'DEFINE VARIABLES
    A VAR WORD
    B VAR BYTE
    C VAR BYTE
    F VAR BYTE
    T VAR WORD
    TRC VAR BYTE[4]
    ARC VAR BYTE[4]
    'EQUATES SECTION
    TRISA = %00111110 'SET PORTS I/O
    TRISB = %00000000
    TRISC = %00000000
    ADCON0 = %00000000
    EEPROM 0,[129,243,73,97,51,37,5,241,1,49] 'STORE CONSTANTS
    LOOP: 'GET T & A FROM PIC 7
    IF PORTA.4 = 1 THEN
    SERIN2 PORTA.0 \PORTA.1,813,[T,A]
    AS = A * 10
    LOOP1: 'DISPLAY T & A
    FOR C = 0 TO 3
    READ T DIG C, PORTB SET SEGMENT
    LOOKUP C,[$7F,$BF,$DF,$EF],PORTC 'SET DIGIT
    PAUSE f
    PORTC = $FF
    NEXT C
    FOR B = 0 TO 3
    READ AS DIG B, PORTB
    LOOKUP B,[$FE,$FD,$FB,$F7],PORTC
    PAUSE f
    PORTC = $FF
    NEXT B
    GOTO LOOP
    THANKS ALL!
    Thanks !
    SOMRU
    TWE/TFP/EE
    Default check this
    Quote Originally Posted by SOMRU
    GREETINGS ALL!!
    'PIC7 SENDING
    DEFINE SER2_BITS 8
    AMPS VAR WORD
    ARX VAR BYTE[4]
    TDIR VAR BYTE
    CDIR VAR BYTE
    SDIR VAR BYTE
    STR1 VAR BYTE
    TIME VAR WORD
    TIMES VAR WORD
    ATEST VAR WORD
    TTEST VAR WORD
    TRX VAR BYTE[4]
    C VAR BYTE
    'EQUATES SECTION
    TRISB = %10011101
    TRISC = %00001111
    ADCON0 = %00000000
    AMP=5678
    GOSUB SND6
    HIGH PORTB.2
    PAUSEUS 40
    Serout2 PORTB.5 \PORTB.6,<font color=red>84</font color>,[TIME,AMP]
    LOW PORTB.2
    'PIC6 RECIEVE
    DEFINE SER2_BITS 8
    A VAR WORD
    B VAR BYTE
    C VAR BYTE
    F VAR BYTE
    T VAR WORD
    TRC VAR BYTE[4]
    ARC VAR BYTE[4]
    'EQUATES SECTION
    TRISB = %00000000
    TRISC = %00000000
    ADCON0 = %00000000
    IF PORTA.4 = 1 THEN
    SERIN2 PORTA.0 \PORTA.1,<font color=red>813</font color>,[T,A]
    AS = A * 10
    FOR C = 0 TO 3
    PAUSE f
    PORTC = $FF
    NEXT C
    FOR B = 0 TO 3
    PAUSE f
    PORTC = $FF
    NEXT B
    GOTO LOOP
    THANKS ALL!
    Hi, now calm down and please stop shouting
    look at the red highlights, I cannot find 84 as valid for serout2 - serin2 yes. if you are trying to send at 9600 baud then why receive at 1200 baud?
    GREETINGS ALL!!
    GOSUB SND6
    HIGH PORTB.2
    PAUSEUS 40
    LOW PORTB.2
    THANKS ALL!
    In the above chunk, you Gosub SND6, the subroutine returns from it, and then you enter SND6, AND it RETURNS...to...nothing. Unless you've got some other code in there somewhere that you took out for brevity, it looks like you've got one of those deals where you're returning without GoSub'ing. That tends to send the PIC into la'la land. Check it out...
    JDG
    Dec 2006
    WADSWORTH OHIO USA
    Default Sending It All
    GREETINGS AGAIN,
    HERE IS THE ENTIRE CODE FOR PIC7
    DEFINE SER2_BITS 8
    AMPS VAR WORD
    ARX VAR BYTE[4]
    TDIR VAR BYTE
    CDIR VAR BYTE
    SDIR VAR BYTE
    STR1 VAR BYTE
    TIME VAR WORD
    TIMES VAR WORD
    ATEST VAR WORD
    TTEST VAR WORD
    TRX VAR BYTE[4]
    C VAR BYTE
    'EQUATES SECTION
    TRISB = %10011101
    TRISC = %00001111
    ADCON0 = %00000000
    AMP = 50 'INITIATE VARIABLES
    AMPS = 50
    CDIR = 0
    STR1 = 0
    TDIR = 0
    TIME = 1000
    TIMES = 1000
    'IT ALL STARTS HERE
    PAUSE 200 'RESTORE PREVIOUS VALUES
    READ 0,TIMES
    READ 1,AMPS
    READ 2,TIME
    READ 3,AMP
    PAUSE 100
    GOSUB SND6 'SEND TO PIC6
    LOP1: 'MAIN LOOP
    'IF PORTA.4 = 1 AND PORTA.5 = 0 THEN SND5 'SEND T&C TO PIC5
    IF PORTC.1 = 1 AND PORTC.2 = 0 THEN TADJ 'TIME ADJUST
    IF STR1 = 1 AND PORTC.1 = 0 THEN TADW 'SAVE TIME WHEN DONE
    IF PORTC.2 = 1 AND PORTC.1 = 0 THEN CADJ 'AMPS ADJUSTMENT
    IF STR1 = 2 AND PORTC.2 =0 THEN CADW 'SAVE AMPS WHEN DONE
    GOTO LOP1
    TADJ: TDIR = 1 'ADJUST TIME SETTING
    IF PORTB.3 = 0 AND PORTB.4 = 0 THEN TDIR = 2 'ZERO NOTCH
    IF TDIR = 2 THEN
    IF PORTB.3 = 1 AND PORTB.4 = 0 AND PORTC.3 = 0 THEN TDIR = 3
    IF PORTB.3 = 0 AND PORTB.4 = 1 AND PORTC.3 = 0 THEN TDIR = 4
    IF PORTB.3 = 1 AND PORTB.4 = 0 AND PORTC.3 = 1 THEN TDIR = 5
    IF PORTB.3 = 0 AND PORTB.4 = 1 AND PORTC.3 = 1 THEN TDIR = 6
    SELECT CASE TDIR
    CASE 1
    GOTO LOP1
    CASE 2
    GOTO LOP1
    CASE 3
    IF TIME < 2790 THEN TIME = TIME + 10
    CASE 4
    IF TIME > 19 THEN TIME = TIME - 10
    CASE 5
    IF TIME < 2799 THEN TIME = TIME + 1
    CASE 6
    IF TIME > 9 THEN TIME = TIME - 1
    END SELECT
    STR1 = 1
    GOSUB SND6 'T OR C CHANGED
    GOTO LOP1
    TADW: READ 0, TIMES 'STORE TIME
    IF TIMES <> TIME THEN WRITE 0, TIME
    READ 0, TTEST
    IF TTEST <> TIME THEN WRITE 2, TIME
    STR1 = 0
    GOTO LOP1
    CADJ: CDIR = 0
    IF PORTB.3 = 0 AND PORTB.4 = 0 THEN CDIR = 2 'ZERO NOTCH
    IF CDIR = 2 THEN
    IF PORTB.3 = 1 AND PORTB.4 = 0 AND PORTC.3 = 0 THEN CDIR = 3
    IF PORTB.3 = 0 AND PORTB.4 = 1 AND PORTC.3 = 0 THEN CDIR = 4
    IF PORTB.3 = 1 AND PORTB.4 = 0 AND PORTC.3 = 1 THEN CDIR = 5
    IF PORTB.3 = 0 AND PORTB.4 = 1 AND PORTC.3 = 1 THEN CDIR = 6
    SELECT CASE CDIR
    CASE 1
    GOTO LOP1
    CASE 2
    GOTO LOP1
    CASE 3
    IF AMP < 2550 THEN AMP = AMP + 10
    CASE 4
    IF AMP > 50 THEN AMP = AMP - 10
    CASE 5
    IF AMP < 2549 THEN AMP = AMP + 1
    CASE 6
    END SELECT
    STR1 = 2
    GOSUB SND6
    GOTO LOP1
    CADW: READ 1, AMPS 'STORE AMPS
    IF AMPS <> AMP THEN WRITE 1, AMP
    READ 1, ATEST
    IF ATEST <> AMP THEN WRITE 3, AMP
    STR1 = 0
    GOTO LOP1
    SND5: IF TIMES <> TIME THEN TIMES = TIME 'SEND TO PIC5
    WRITE 0, TIME
    IF AMPS <> AMP THEN AMPS = AMP
    WRITE 2, AMP
    SEROUT2 PORTC.5\PORTC.6,84,[TIME,AMP]
    GOTO LOP1
    'SUBPROGRAM SECTION
    HIGH PORTB.2
    PAUSEUS 40
    LOW PORTB.2
    AND HERE IS THE ENTIRE CODE FOR PIC6
    DEFINE SER2_BITS 8
    A VAR WORD
    B VAR BYTE
    C VAR BYTE
    F VAR BYTE
    T VAR WORD
    TRC VAR BYTE[4]
    ARC VAR BYTE[4]
    'EQUATES SECTION
    TRISB = %00000000
    TRISC = %00000000
    ADCON0 = %00000000
    A = 0 'INITIATE VARIABLES
    AS = 0
    B = 0
    C = 0
    F = 2
    T = 0
    'IT ALL STARTS HERE
    PAUSE 200
    IF PORTA.4 = 1 THEN
    SERIN2 PORTA.0 \PORTA.1,84,[T,A]
    FOR C = 0 TO 3
    READ T DIG C, PORTB
    PAUSE f
    PORTC = $FF
    NEXT C
    FOR B = 0 TO 3
    PAUSE f
    PORTC = $FF
    NEXT B
    GOTO LOOP
    PIC7 IS TO STORE AND ADJUST THE TWO VARIABLES FOR TIME AND CURRENT,
    SEND IT TO PIC5 AND PIC6 UPON DEMAND
    TRYING TO PULL RABBITS FROM HAT AT THIS POINT,
    APPOLOGIES FOR SHOUTING
    THANKS ALL!!
    Thanks !
    SOMRU
    TWE/TFP/EE
  1. PBP 2.60 & ADCON1 problem
    By bitbangerbob in forum mel PIC BASIC Pro
    Last Post: - 21st October 2009, 12:06
  2. Strange problem with PBP 2.50
    Last Post: - 16th October 2007, 20:45
  3. Big Problem in PBP To receive DMX
    By programmer07 in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 18:49
  4. Problem with PBP interrupt and Serin, please help
    By rgregor in forum mel PIC BASIC
    Last Post: - 22nd August 2006, 19:02
  5. Problem DEFINE OSCCAL and PBP 2.46
    By David in forum mel PIC BASIC Pro
    Last Post: - 22nd April 2005, 17:19
