Real Time Clock
Results 1 to 6 of 6
Thread: Real Time Clock
    Jun 2006
    Default Real Time Clock
    I am looking for code to make real time clock for pic16f88.
    I will use it with LCD with 2 lines.
    In first line show the time. Like this : 00:00:00 ,
    and the second line the date-month and year. Like this : 07-012-2006
    Any help is aceptable.
    Jan 2006
    Istanbul
    Com'on Savnik,
    Don't do this to us! You are an experienced member of this forum!
    1. http://www.picbasic.co.uk/forum/showthread.php?t=423
    2. http://www.picbasic.co.uk/forum/showthread.php?t=2129
    3. http://www.picbasic.co.uk/forum/showthread.php?t=632
    Jun 2006
    Quote Originally Posted by sayzer
    Com'on Savnik,
    Thank you , but i don't think i am an experience member.
    I have see these links.
    Jan 2006
    Istanbul
    OK.
    Do you want to use RTC chip or you want to use a timer module of the PIC to do this?
    if you use a timer module, it has its own headache; may become too complicated at some point. You can see that in the links I posted.
    if you use an RTC chip, it is easier and you get less headache (if any).
    Jun 2006
    I want to use a timer module of the PIC to do this.
    Mentor, Ohio
    Smile
    Hi Savnik,
    If you want a RTC using a timer module then look at the #2 example above. It does not have the day, month, & year but with a small amount of your time, you should be able to add that part to the program. I have built both clocks as posted and I thought they were very good projects. I have also built numerous projects using the DS1337 RTC chip. Using the 1337 I was able to add routines for DST.
    HTH,
    BobK
  1. real time clock
    By maria in forum Code Examples
    Last Post: - 1st March 2022, 13:13
  2. Real Time Clock
    By in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2012, 05:52
  3. real time clock - PCF8583
    By maria in forum mel PIC BASIC Pro
    Last Post: - 15th April 2010, 16:41
  4. Real time clock ICs
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 20th October 2008, 17:05
  5. Real time clock... what a headache!
    Last Post: - 8th June 2006, 22:56
