Need cheap i2c LCD for 16F877a
Results 1 to 5 of 5
    Smile Need cheap i2c LCD for 16F877a
    Hi, Can anyone reccomend a simple, text only LCD capable of being accesed as an i2c slave? The ones I have seen so far are around £50, surely there are some in a cheaper price bracket?
    The LCD is to be used with the ME Labs LABX2 project board and 16F877A.
    I have found some suitable code in these forums posted by Mister_e (thanks) for setting up and writing to an lcd but as I am still new to this hobby would appreciate, if you have it, code specific to the LCD you might reccomend.
    Thanks for your help. For someone who is emerging from the technically simplified world of picaxes these forums are invaluable.
    Cheers
    is there any specific reason why you want a I2C LCD?
    You could still build your own interface+ any cheap standard LCD?
    The simple solution is still the serial LCD.
    Start:
    SERIN ....
    LCDOUT .....
    goto start
    Default Advantage of i2c
    I think I am correct in believing that the i2c connection will only use 2 pins whereas the serial connection requires several? I need all my available pins.
    Mark
    Nov 2006
    Murrieta, CA
    Exclamation SERIAL 4x20 LCD
    Um..... I use the Parallax 4x20 Serial LCD display... it only uses ONE line for serial transmission. take this simple code to send hello to the display
    DIFINE OSC 20 'Always define the Oscillator your using !!
    SEROUT PORTA.5,2,["Hello"] '9600 baud True Driven will send this to the display
    And here are some other Good commands:
    SEROUT PORTA.5,2,[$11] 'This command will enable the Backlight $12 disables
    SEROUT PORTA.5,2,[$0C] 'This will clear the Display
    pause 5
    It is Very Easy to use and program.... remember only Power ground and 1 wire for serial communication !!!
    view the LCD DataSheet here
    There are 10 kinds of people. Those that know binary and those that do not.
    But building your own is so simple... SERIN, LCDOUT is all you need. Perfect application for a 16F84 and all other gathering dust LMAO!
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  3. Play with LCD on PICDEM
    Last Post: - 22nd August 2008, 17:56
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Need help with LCD number display.
