Here's the whole Code, I tried to use NAP in place of PAUSE and the LED stays on for the alloted time but the blink part does not work. I've also attached a variant to the blink part which also failed to blink the LED.
; Define statements.
define NO_CLRWDT 1 ;Don't insert CLRWDTs
define OSC 20 ;every MPU used is 20mhz
'Port operation configurations
CMCON0 = %00000111 'Port A all digital
VRCON = %00000000 'CVref turned off
OPTION_REG = %10000111 'Disable PORTA pullups, set TMR0 scaler to 1:256
; Program Variables
Loop VAR BYTE ;general loop counter for LED flashing
Outp CON 0
Inp CON 1
'Assign Ports to simple name
LowVoltage VAR PortA.0 'Battery low voltage detection port
ReedSwitchState var PORTA.1 'Reed Switch ON and OFF state line
LED VAR PORTA.2 'Turn LED ON and OFF
HoldTxON VAR PORTC.0 'Hold Tx ON when water contacts activated
Tx_Data VAR PORTC.1 'Transmit Data Line
Tx1_Enable VAR PORTC.2 'Transmit 121.5Mhz Line
Tx2_Enable VAR PORTC.3 'Tranmit 156MHz Line
MotorControl_1 VAR PORTC.4 'Activate Release Mechanism
MotorControl_2 VAR PORTC.5 'Activate Latch Mechanism
'Initialize port states
TrisA.0=Inp 'set batt low voltage detection to input
TrisA.1=Inp 'set Reed switch state to input
TrisA.2=Outp 'set led transmission to output
TrisC.0=Outp 'set Hold Tx Line ON to output
TrisC.1=Outp 'set Transmit data line to output
TrisC.2=Outp 'set Transmit @121.5 to output
TrisC.3=Outp 'set Transmit @156 to output
TrisC.4=Outp 'set Motorcontrol_1 to output
TrisC.5=Outp 'set Motorcontrol_2 to output
'Goto Main
low HoldTxON ; Initialize by clearing all the outputs
low LED
low Tx_Data
Low Tx1_Enable
low Tx2_Enable
Low MotorControl_1
LOW MotorControl_2
GOSUB Lowvoltagecheck
; Subroutine to check for battery voltage at the beginning and end of
; transmission flashing to signify low voltage or high voltage
LowVoltageCheck:
If lowVoltage = 1 then ; If the battery voltage is OK
high led ; turn on the LED for 5 seconds
pause 5000
LOw LEd
for loop = 1 to 10 ; If the battery voltage is low
high led ; Flash the LED 10 times
Pause 500 ; at a rate discernable from the
low led ; transmit LED flash rate
next
PS: This is the code I used to try and break up the subroutine further for testing but failed to work also.
LowVoltageCheck:
If lowVoltage = 1 then GoodBattery
if lowvoltage = 0 then LowBattery
LowBattery:
gosub Blink
next loop
Blink:
pause 500 ; at a rate discernable from the
GoodBattery: ; If the battery voltage is OK
pause 5000
LOw LEd
