hyperterminals commands
Results 1 to 13 of 13
    Feb 2005
    Default hyperterminals commands
    i would like to know some commands to sent from pic to hyperterminal like clear screen e.t.c
    thanks
    santamaria, I use VT-100 commands for terminal control. If you do a search for VT-100 commands you will find quite a list. Here are some control codes I have used in the past to control ternimals connected to my products:
    INITS: 'INITIALIZE TERMINAL
    CLRS:
    SEROUT2 TX1,TX1BAUD,[27,91,72] 'HOME CURSOR
    SEROUT2 TX1,TX1BAUD,[27,"[1J"] 'CLEAR SCREEN
    POSITION: 'POSITION CURSOR ON LINE & COLLUM
    SEROUT2 TX1,TX1BAUD,[27,91,"H"]
    SEROUT2 TX1,TX1BAUD,[27,91,DEC LINE,";",DEC COLLUM,"f"]
    Feb 2005
    thanks for your quick answer.i check this commands that you post and working fine.i will search it for more commands.
    santamaria
    Hi santamaria,
    ANSI codes for Hyperterminal
    http://www.pbpgroup.com/modules/wfse...hp?articleid=9
    May 2005
    Ne ohio
    Default ansi codes
    Darrel,
    I included your ansi.inc file and tried a compile but mpasm gave errors.
    sonmething about "found label after column 1" and
    a few illegal charcters.
    I'm using pbp in Microcode studio and Mpasmwin.
    I only included the .inc file and did not use any of the macros.
    thanks,
    Brian
    Hi ptig185,
    Make sure you have at least 1 HSEROUT statement in your main program.
    The include file uses the HSEROUT?C macro's, but it doesn't uses an HSEROUT itself. So PBP doesn't include the HSEROUT?C macro unless you have an HSEROUT statement somewhere in your program.
    HTH,
  1. LCD commands
    Last Post: - 26th September 2008, 12:09
  2. DS2480D commands
    By manwolf in forum mel PIC BASIC Pro
    Last Post: - 21st June 2008, 05:32
  3. PBP - are DEFINE command(s) mandatory?
    Last Post: - 15th September 2006, 16:43
  4. Replies: 0
    Last Post: - 28th June 2006, 12:54
  5. Timing in PICBasic Pro commands
    By freelancebee in forum mel PIC BASIC Pro
    Last Post: - 11th September 2005, 00:50
