driving APR6008
Results 1 to 3 of 3
Thread: driving APR6008
    Dec 2006
    Default driving APR6008
    has anybody code for driving apr6008 with microcontroller.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by mech
    No, but I did drive an 83vette once....NOT! And I changed a waterpump in a 68 Volksvagon Bug too.
    If you'd have Google'd this apr6008 chip, you'd have found 634 hits, most with datasheets. A basic SPI will do, but you can get more complicated if you want.
    JDG
    Sep 2003
    INDIA
    Default APR6008 / APR6016 Code help
    Even I am looking for code help. Its Similar to the ISD4002 and if you check / search the forum for ISD4002. Nick has got something on it.
    I have just got the PCB's made for the APR60xx and would be testing my code on it. Remember its 4.5V Supply. IO pins should be lower than 4V, Won't work otherwise. I also understand that MISO does not work. Please check.
    regards
  1. Ultimate 7-Segment Driving Example
    By sayzer in forum Code Examples
    Last Post: - 16th June 2009, 16:14
  2. Problem driving a laser pointer
    By Louis Cimon in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2008, 15:49
  3. destroying my last pic? driving a miniature motor
    By Michael Wakileh in forum Schematics
    Last Post: - 28th August 2007, 10:38
  4. Help Rqd - Driving 5Volt Relay using two pins
    By Squibcakes in forum mel PIC BASIC Pro
    Last Post: - 5th October 2005, 02:54
  5. Driving a logic-level HEXFET
    By thelightbrain in forum mel PIC BASIC Pro
    Last Post: - 11th November 2004, 00:34
