OK.. you're using an external OSC, BUT not the MCLR pin, so just make MCLR pin as I/O OR tie it to Vdd via 10K resistor... it should work Better.
If you're using an external OSC, the OSCCON stuff won't change anything. So i bet that..
@ DEVICE PIC16F88, HS_OSC 'HS oscillator
@ DEVICE PIC16F88, WDT_ON 'Watchdog Time
' (http://www.hobbyprojects.com/pic_tut...utorial13.html)
@ DEVICE PIC16F88, PWRT_ON '15.5 Power-Up Timer: Provides a fixed delay of
' 72 ms (nominal) on power-up only. It is designed to keep the
' part in RESET while the power supply stabilizes.
@ DEVICE PIC16F88, BOD_ON '15.7 Brown-Out Detect
@ DEVICE PIC16F88, MCLR_OFF 'Master Clear Options set to Internal. RA5 unavail
@ DEVICE PIC16F88, LVP_OFF '15.18 Low Voltage Programming via ICSP.
@ DEVICE PIC16F88, CPD_OFF '15.1 bit 8 - Data EE Memory Code Protection bit
@ DEVICE PIC16F88, WRT_OFF '15.1 bit 10-9. FLASH Program Memory Write protection off
@ DEVICE PIC16F88, DEBUG_OFF '15.1 bit 11. DEBUG: In-Circuit Debugger Mode bit
' In-Circuit Debugger disabled, RB6 and RB7 are general
' purpose I/O pins
@ DEVICE PIC16F88, CCPMX_OFF '15.1 bit 12. CCPMX: CCP1 Pin Selection bit
' 1 = CCP1 function on RB0
' 0 = CCP1 function on RB3
@ DEVICE PIC16F88, PROTECT_OFF 'Code protection off
could help
