Simple doubt PIC16F505
Results 1 to 11 of 11
    Feb 2005
    Portugal
    yes, but what's the instruction to clear in option_reg<5>
    clear ?
    Option_reg.5 = 0
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    Portugal
    Thank you.
    Feb 2005
    Portugal
    Sorry but another questions concerning PIC16F505.
    When i drive my relay it seems my PIC reset's, because it goes to my programs beginning.
    I already put my "master clear enable" to internal and external and nothing. What i can do in software without change my hardware.
    I already had a similar problem in pic16F872 and i resolved putting a 10uF capacitor near my +5V.
    There are other without changemy hardware?
    Jan 2006
    Istanbul
    On software side, you can play with BOD_OFF / BOD_ON,
    and also WDT_OFF / WDT_ON
    I suggest that you go one by one so you will know which one works for you.
    Feb 2005
    Portugal
    I tried but i think it's not working.
    But i'll try more... If you remember another way to do it???
    Sep 2003
    Vermont
    How much current is the relay drawing? Do you have a protection diode across it?
    Ron
    Default Sayzer said," "
    Quote Originally Posted by sayzer
    On software side, you can play with <font color=green>BOD_OFF</font color>
    Hi leonel, check what sayzer said here.
    When your relay pulls, in the input voltage drops and the PIC likely reboots due to brown out reset fuse set on, the capacitor helps supply that inrush current and prevents the brown out reset.
    JS
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 10:45
  2. A Serial GLCD 128x64 Simple Project
    Last Post: - 8th March 2010, 20:58
  3. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 06:19
  4. Replies: 4
    Last Post: - 7th September 2005, 14:11
  5. Simple Serial communications
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 18th July 2005, 19:42
