LCD Serout
Results 1 to 10 of 10
Thread: LCD Serout
    Nov 2006
    Murrieta, CA
    Talking LCD Serout
    Hello all,
    I am trying to test my LCD. I am using Demo Version of PBP and it will not allow me to use Include Files.
    If someone can compile the program below so that i may test my LCD i would appreciate it...
    Once i test my board Fully and know the PBP works i will purchase...
    also, if someone could even let me know if the program below will even work I would appreciate that too. I am using a Parallax 4x20 LCD @ 9600 Baud. I am using a PIC16F876A device.
    Gary D.
    INCLUDE "modedefs.bas"
    SEROUT PORTA.5,N9600,["Hello World"]
    Feb 2003
    If you look in the Modedefs.bas file or the "Serout" section of the PBP manual you will see that N9600 is defined as
    N9600 = 6 ' Driven Inverted
    Do either of the following
    N9600 CON 6 ' Driven Inverted to declare the constant
    or
    SEROUT PORTA.5,6,["Hello World"]
    Both should compile as you arent using any include files.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Nov 2006
    Murrieta, CA
    Cool RE: LCD Serout
    Ok,
    Awesome...
    i have some activity but i think that the LCD is not getting enough Power.
    Thanks a lot for your help !!
    Gary D.
    Feb 2003
    Quote Originally Posted by RFEFX
    If it wasnt getting enough power it wouldnt work.
    Assuming it is displaying the characters you sent then it probably just needs the contrast adjusting.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Nov 2006
    Murrieta, CA
    Question Whoa !! Can Pic even program Parallax LCD?
    Ok.... I have been tying to program this LCD for the last couple days..
    Im using the PIC16F876A on PORTA.5
    The LCD Specs are Here
    when i send
    SEROUT PORTA.5,6,["Hello"]
    or when i send
    SEROUT2 PORTA.5,84,["hello"]
    I get nothing but the Cursor moves around a lot.
    Has anyone got code for the Parallax LCD 4x20 Module.
    There are 10 kinds of people. Those that know binary and those that do not.
    you have to disable the analog A/Ds
    ADCON1=7
    And probably analog comparator
    CMCON=7
    Nov 2006
    Murrieta, CA
    Default Whoa !!
    Nope... Still nothing....
    Is the Test mode work?
    If so, set it to 2400 Bauds,, reset the LCD module and try...
    ADCON1=7
    CMCON=7
    HIGH PORTA.5
    PAUSE 500
    SEROUT PORTA.5,4,["Hello"]
    Z: goto Z
    AND this one
    ADCON1=7
    CMCON=7
    DEFINE DEBUG_REG PORTA
    DEFINE DEBUG_BIT 5
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 0
    HIGH PORTA.5
    PAUSE 500
    debug "Hello"
    Z: goto Z
    If i refer to their datasheet and the code example, it must be driven TRUE.
    Wich osc speed are your using?
    Nov 2006
    Murrieta, CA
    Default Nope !
    LCD start up test works...
    I am running a 20Mhz Crystal Oscillator in HS mode...
    LCD is receiving data just not what i send it... Just a bunch of characters.
    Gary D.
    Nov 2006
    Murrieta, CA
    Exclamation SEROUT Problem Solved
    since I was using the PIC16F876A in HS mode with a 20Mhz Clock... I failed to define the OSC....
    ADCON1=7
    CMCON=7
    DEFINE OSC 20
    and there you have IT... Serial LCD works like a charm...
    Thanks to all that helped.
    Last Post: - 8th March 2010, 20:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 16:46
  3. Play with LCD on PICDEM
  4. LCD will not start
  5. LCD with serout command
    By azispn99 in forum mel PIC BASIC Pro
    Last Post: - 6th April 2006, 13:08
