433mhz
Results 1 to 7 of 7
Thread: 433mhz
    Sep 2006
    Venezuela - Caracas
    Thumbs up 433mhz (solved)
    i use 2 circuits
    1 - 16F628
    1 - Transmiter
    2 - 16F628
    2 - Receive
    1 - code - Transmit
       INCLUDE "modedefs.bas"
       Transmissor_Saida       VAR    PORTA.2 '
       Dados              var    byte
       Sincronismo        var    byte
       Codigo_Teste       var    byte
       CMCON          =     7                 ' PortA = digital I/O
       VRCON          =     0                 ' Voltage reference disabled
       OPTION_REG.7   =     0                 ' Enable PORTB pull-ups
       codigo_Teste   =     "©"
       Sincronismo    =     "®"
    Inicio:
       for dados =  33 to 255
          serout Transmissor_Saida, T2400, [codigo_Teste, sincronismo, dados, codigo_Teste]
          PAUSE 1
       next
       serout Transmissor_Saida, T2400, ["END", 13, 10]
    goto inicio
    2 - code - Receive
       Serial_Entrada     VAR    PORTA.3      ' 2 Pic Rx -> 9  Max 232 Tx Marron
       Serial_Saida       VAR    PORTA.2      ' 1 Pic Tx -> 10 Max 232 Rx Laranja
       Receptor_Entrada   VAR    PORTA.1      ' 1 Pic Rx -> 9  Receptor data
       Dados              var    byte
       codigo_Teste   =     "©"
       Sincronismo    =     "®"
       serout serial_saida, T2400, ["Inicio", 13, 10]
    Inicio:
       'SERIN serial_entrada, T2400, [CODIGO_TESTE, SINCRONISMO], DAdos
       'SERIN receptor_entrada, T2400, [CODIGO_TESTE, SINCRONISMO], DAdos
       SERIN receptor_entrada, T2400, DAdos
       SEROUT SERIAL_SAIDA, T2400, [DAdos, 13, 10]
    gOTO inicio
    my problem is than in receive,
    Dados = "["
    i not receive "[", "]", A
    in hyperterminal i receivce 10 caracter "["
    i use this code for test http://www.rentron.com/Stamp_RF.htm
    Jan 2006
    Istanbul
    I am no expert but,
    1. You send three variables : T1, T2, and A.
    Then you have one variable, DAdos, in your receiver to receive them.
    You should have three variables in receiver.
    2. You use T2400 in your sender.
    But you have T1200 in your receiver.
    Well, according to your code you are sending at 2400baud and recieving at 1200. That will not work....
    Also, on your reciever, you are telling SERIN to recieve one byte (DAdos). If you are sending three bytes you need to tell SERIN to recieve 3 bytes.
    DAdos var byte
    Temp1 var byte
    Temp2 var byte
    SERIN SER_IN, T1200, DAdos, Temp1, Temp2
    SEROUT SER_OUT, T1200, DAdos, Temp1, Temp2, 10, 13
    '....and so on
    You can also try:
    DEFINE CHAR_PACING 1000    'Serout character pacing in us
    Perhaps that will help.
    /Henrik Olsson.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by mpardinho
    i use 2 circuits
    1 - 16F628
    1 - Transmiter
    2 - 16F628
    2 - Receive
    1 - code - Transmit
    T1 = "["
    T2 = "]"
    start:
    For A = 1 to 10
    SEROUT SERIAL_OUT, T2400, [T1, T2, A]
    next
    goto start
    2 - code - Receive
    start:
    SEROUT SER_OUT, T1200, [DAdos, 13, 10]
    goto start
    Dados = "["
    You send 3 numbers and only receive one...how's that going to work?
    You send at 2400, receive at 1200...how's that going to work?
    Also, I don't see anything set up to synchronize the receiver, nothing relating to manchester encoding your data, and I could go on.
    Read thru the example at Rentron's site a bit more before you start in again.
    JDG
    Sep 2006
    Venezuela - Caracas
    pardon....both are T2400.. rewrite post...my real code
    i will try DEFINE CHAR_PACING 1000 and post the results
    many thanks brothers
    Jan 2006
    Istanbul
    Don't scare him skimask!
    Not having that much experience is not a crime nor is making mistakes.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by sayzer
    No scaring going on here. Just pointing out the blatently obvious...again.
    JDG
  1. Replies: 2
    Last Post: - 29th September 2007, 06:49
  2. 433MHz RF PIC2PIC connection
    By NavMicroSystems in forum mel PIC BASIC Pro
    Last Post: - 5th February 2006, 15:44
