HserIn and Interrupts
Results 1 to 8 of 8
    Mister-E, Thanks for the response.
    Yes, it's been working flawless since then. My development board as pull ups and downs configurable by a jumper and somehow I changed it (removed the jumper) and caused all this greif.
    Good!
    wich development board? I guess it's MikroElektronika? If so they're really nice for the price and included hardware... the only problem.. the on-board programmer.. sometimes it fails, the RS-232.. there's no free DTR line for the bootloader... but an on-board reset, there's no easy way to change/disable the on-board crystal capacitors.
    EasyPIC 4 KIT:
    Pricing vs what you get 10/10
    Documentation 9/10
    Assembly 8/10
    Electronic design 7/10
    Overall 8/10.
    Good stuff from the 10F to 18Fs, from 8 dip pins to 40Dip pins. By far, the best PIC development board on the market.
    Quote Originally Posted by mister_e
    Good!
    wich development board? I guess it's MikroElektronika? .
    Yep, EasyPic3. Overall I love it. It has a few flukes, but your right, it's one of the best values around. They most likely sell that board for cost in order to get the name / compiler out there for folks to try.
    Right now, I'm using a ZTT-20mhz with the built in caps, and the onboard caps are still there as well but so far it hasn't caused any issues.
    While we're talking about it, I really like using the 3 pin ZTT's but I heard going with a crystal and seperate caps is much more reliable as far as wide temperature swings. I honestly figured the 1 package with the caps encapsulated would be better for less drift due to wide temp. swings.
    Any experience here, which do you prefer?
    You're right. If it's really timing critical i'll use crystal. unless, i'll use resonator. Resonator are good so far, so don't worry.
    I heard that some resonator may have a shorter lifetime... i can't confirm, i never replaced any since i use them.
  1. Hserin with Instant Interrupts.
    By ronjodu in forum Serial
    Last Post: - 30th December 2014, 20:17
  2. DT interrupts and Pause
    By Luckyborg in forum mel PIC BASIC Pro
    Last Post: - 18th February 2009, 22:47
  3. Instant Interrupts and HSERIN
    By Rob in forum mel PIC BASIC Pro
    Last Post: - 31st January 2009, 05:13
  4. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 11:48
  5. Usbin and hserin
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 27th October 2007, 15:26
