More detail could be handy here.
"...write feedback procedure which can allow control output voltage regardless of current" does this mean that you need feedback for speed no matter what the current is?
Simple RPM reading for example; if the speed is lower, then you increase the motor supply through PWM, and if the speed is higher, then you decrease it.
Is this what you asked for?
