PCB - Cadsoft EAGLE users - help needed
Results 1 to 12 of 12
    Default New Question.
    I'm using Eagle from Cadsoft and im having issue with not being able to place parts in exact postions. The only way to move parts that I can see is with the mouse. Is there a command I'm missing that will allow me to move a given part a specifc distance like move X,Y.
    Have you tried to change the grid?
    I did try the grid and the alt grid but I was looking for something more along the lines of move to X,Y cords so that I can easily pop down parts where I know they need to be instead of dragging them around to get to the same spot.
    Yes, I understand what you mean. I use the indicators for the x-y cordinators to place parts. The difficult is when you have a part that its cross is not on its corners, but somewhere in the middle.
    Yea you kinda need to have your own parts designed to have it all work like expected I guess but I did find the move command if anyone is interested.
    To move a resistor named R1 its move R1 (X Y)
    Nov 2006
    Default eagle-filling the board
    I've been using eagle a bit, and I have found it necessary to build a number of devices. It's a bit of a struggle at first, but once it's done it's done.
    Since we're on this subject, does anyone know a way of automatically filling in space on circuit boards? I make my own boards, so the less copper I etch away the better. As of now I have to put in a bunch of squares and triangles manually, and when I want to change something on the board, I have erase many of them and put them back. Now that I think of it, there may be a way to do this with photoshop or something just before printing the negative (basically draw black lines around all objects). Any thoughts?
    Dec 2005
    I've used P.C Logic - Circuit Layout for several years but they went out of business.
    I found Eagle had too difficult a learning curve, plus it's costly for the fully featured versions.
    I've been looking for something easy to learn and inexpensive, yet with advanced features. I found it in Sprint - Layout. Among its features is automatic ground planes with user settable clearance - a single mouse click turns it on or off. It doesn't allow precise X,Y placement of parts but, when necessary, it's quick and simple to break a part into individual entities which can be placed by X,Y and then regroup the individual entities. There's a demo version but I didn't try it so cannot tell you its limitations. The learning curve was a matter of minutes. At $50, it is an amazing bargain.
  1. Replies: 0
    Last Post: - 14th April 2007, 07:17
  2. schematic drawing
    By saturnX in forum Schematics
    Last Post: - 16th July 2006, 23:45
