Need cheap i2c LCD for 16F877a
Results 1 to 5 of 5
    is there any specific reason why you want a I2C LCD?
    You could still build your own interface+ any cheap standard LCD?
    The simple solution is still the serial LCD.
    Start:
    SERIN ....
    LCDOUT .....
    goto start
    Default Advantage of i2c
    I think I am correct in believing that the i2c connection will only use 2 pins whereas the serial connection requires several? I need all my available pins.
    Mark
    Nov 2006
    Murrieta, CA
    Exclamation SERIAL 4x20 LCD
    Um..... I use the Parallax 4x20 Serial LCD display... it only uses ONE line for serial transmission. take this simple code to send hello to the display
    DIFINE OSC 20 'Always define the Oscillator your using !!
    SEROUT PORTA.5,2,["Hello"] '9600 baud True Driven will send this to the display
    And here are some other Good commands:
    SEROUT PORTA.5,2,[$11] 'This command will enable the Backlight $12 disables
    SEROUT PORTA.5,2,[$0C] 'This will clear the Display
    pause 5
    It is Very Easy to use and program.... remember only Power ground and 1 wire for serial communication !!!
    view the LCD DataSheet here
    There are 10 kinds of people. Those that know binary and those that do not.
    But building your own is so simple... SERIN, LCDOUT is all you need. Perfect application for a 16F84 and all other gathering dust LMAO!
  1. I2C Master/Slave 16F88/16F767 working code
  2. HARDWARE I2C SAMPLE CODE question
  3. Play with LCD on PICDEM
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 19:33
  5. Need help with LCD number display.
