Compiled Hex File does not have Config Word
Results 1 to 3 of 3
    Default programmer
    Quote Originally Posted by GoingMad
    Hello to one and all,
    Please can someone let know if they have had a similar problem or if I HAVE to use the Epic Programmer. I have tried everything I can think of including trying to run a modified .asm file generated by Pic Basic Compiler through MPASM.
    GoingMad
    Hello, I read his book and assembled most of his projects. I use a JDM clone programmer I got off ebay for 12 bucks. It programmed all his code no problem although I had to set the config fuses manualy, as I did not know how to set them in code as he neglected to include that in his book. I learned it here. So I would have to say, no I do not believe you have to get an epic programmer to use PIC Basic Pro, even if that is what they recommend. Now you may choose to use it, I didn't because I was unwilling to pay for it. The JDM clone has not failed to program any supported device I have tried. What programmer
    software are you using? You have to tell micro code studio to use your particular software or it will default to epic and it will not run your programmer. ICPROG workes for me and is freeware on the internet. http://www.ic-prog.com/index1.htm
    JS
  1. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  2. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  3. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  5. calculation problem
    Last Post: - 31st March 2006, 16:23
