nokia 3210 data cable (datasheet)
Results 1 to 7 of 7
    Quote Originally Posted by joseph Degorio
    mister_e, do you have a pattern to connect the nokia 3210 output pin (6 pins) to the communication port 1? I'm really new to this...
    Thanks again in advance,
    Joe
    It's right there in the datasheet. What more do you want?
    maybe those?
    http://www.mbarron.net/mbus/
    http://pinouts.ru/CellularPhonesCabl...l_pinout.shtml
    sorry, i don't have a clue on what you're after
    Thumbs up thanks again mister_e
    I appreciate taking time to give the information. What I'm trying to do is to use a 3210 data cable(switch F/Bus) to COM1. But unfortunately I can't find the cable I need(I'm in a rural area). The one that I see at the cellphone store the data cable at one end has RJ45 connector not Female com connector. I need to use it to send sms information(command) to cellphone attached to the pc and register to my database application and to switch a load(ex. motor) from the parallel port. (Just an experiment for school).
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
