eeprom how many data can store
Results 1 to 9 of 9
    Example... this assumes that your external EEPROM has a device address of $A0 (see your chosen EEPROM's Datasheet) and is of the 24LC32/24LC64 type). SCL is the PIC pin you are using for the I2C Clock line, SDA is the PIC pin you are using for the I2C Data line.
    	'	Subroutine Writes BYTE to External EEPROM
    SetDataExternal:
    		' I2CData - General BYTE variable
    		' I2CDeviceAddress - Hardware Device Address - BYTE variable
    		' I2CDataAddress - Address in EEPROM - WORD variable
    	I2CDeviceAddress=$A0
    	I2CWrite SDA,SCL,I2CDeviceAddress,I2CDataAddress,[I2CData]
    	Pause 10
    and the opposite to read...
    	'	Subroutine Reads BYTE from External EEPROM
    GetDataExternal:
    	I2CRead SDA,SCL,I2CDeviceAddress,I2CDataAddress,[I2CData]
    For further information lookup the I2CREAD and I2CWRITE commands in your PBP manual and compare the examples against the EEPROM Datasheet.
    Nov 2006
    Post Erase the eeprom
    Hi Melanie
    Thanks you...
    Can I know do I need to erased the external eeprom (24LC32) once i write it or once I programmed it???
    Which mean that I have to use I2write command to write all the data (365's sunrise times to the external eeprom)?? So I have to put the I2write command right after the all declaration and initialization.
    Thanks to your basic guideline. I will try this out.
    Nov 2006
    Post 2 interrupt at the same time
    Hi Melanie
    Can I know it is possible to use 2 interrupt in a single program as i am using PIC16F876A?
    (i) TMR0 using to create 1 second elapsed time to create date and time.
    (ii) TMR1 using as sending 4.32 second pulses to the stepper motor driver ucn5804B.
    It is possible ??
    Please advice..
    Thanks you very much.
    The content of a new EEPROM is unpredictable, all locations should be set to $FF but this cannot be guaranteed. It is simple to bulk erase an EEPROM with your PIC programmer (always assuming your programmer is capable of handling EEPROMS).
    If you write to the EEPROM, the content is retained even with the power removed.
    Yes you can have as many interrupts as you want, but your program becomes more complex.
  1. Data EEPROM gets clobbered during programming
    Last Post: - 18th July 2008, 03:46
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  3. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 20:42
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
