eeprom how many data can store
Results 1 to 9 of 9
    Nov 2006
    Post eeprom how many data can store
    Hi all
    Could I store 365 data in the eeprom??????? I am using PIC16F84A.
    If can not, can u suggest me how many data that I can store in the eeprom or other places. Thanks.
    For example: I want to store time 12:13 pm into a place.
    a var word
    c var byte
    'some initialization
    On INERRUPT exit
    EEPROM 0, [$0c0d]
    main: READ 0,a.highbyte
    READ 1,a.lowbyte
    c= a.highbyte - 5 ' return 7am
    IF hour = c THEN ' check 7:13 am
    IF second = a.lowbyte THEN '
    low PORTB.0 ' motor start
    GOTO main
    DISABLE
    exit:
    'Interrupt will accur every 65.536 msec
    'some program code here to calculate time using tmr0 interrupt
    INTCON.2 = 0 ' clear flag
    RESUME
    The return value below is it correct ???????
    a.highbyte=$0c ' 12
    a.lowbyte= $0d ' 13
    c = 7
    Have you looked at the DATASHEET for the 16F84?
    If you haven't please download it from the Microchip website.
    The size for the on-board EEPROM for any PIC is usually found on Page 1 of the Datasheet. You can determine if it is sufficient for your needs from there.
    Please Look at the DOCUMENTATION for the EEPROM command. You can only play with BYTES... therefore...
    EEPROM 0,[$0C,$0D]
    or
    EEPROM 0,[12,13]
    Nov 2006
    Post mistaken and help
    First of all thanks to your reply and advice.
    Sorry for the mistaken. What i mean is c = a.highbyte + a.lowbyte.
    I have looked on the datasheet for the PIC16F84A, the space is 64 bytes for eeprom. I know it is impossible for me to store in the 365 data into the eeprom.
    Do you have any suggestion?
    How about other places such as program memory or RAM?
    I am thinking of using PIC16F876 but it is only 256 bytes only.
    I just want to store the time(sunrise time) for 365 day to anything places that available so that i can read it thru the date.
    for example: 1 jan 06 the sunrise time is 6:10 am
    2 jan 06 the sunrise time is 6:15 am
    and so on.
    Please advice and thanks you very much.....
    Example run again...
    a.highbyte=$0c ' 12
    a.lowbyte= $0d ' 13
    c = $19 (25 Decimal)
    Remember if you are adding two BYTES together, the result may be bigger than a Byte...
    If a and b are hours and minutes, you can't just add them together... you must convert everything to minutes...
    c=(a*60)+b
    Use an external I2C EEPROM like a 24LC32 (4k) or 24LC64 (8k)for your storage (see I2CWRITE and I2CREAD commands in your PBP manual).
    Nov 2006
    Post Change to PIC16F876A
    Hi all
    First of all ,thanks to Melanie again.
    I had planned to use the external eeprom but i have not knowledge on using.
    I had gone thru the PBP manual but I still cant catch it.
    Can you please guide me to the basic so that I could start it easily?
    The overall of the code I will do it on my own and if i got any question then I will ask you. Is that ok?
    I had planned to use the PIC16F876A due to shortage of my I/O port.
    Is that the same ways using the I2Write and I2Read?????
    Example... this assumes that your external EEPROM has a device address of $A0 (see your chosen EEPROM's Datasheet) and is of the 24LC32/24LC64 type). SCL is the PIC pin you are using for the I2C Clock line, SDA is the PIC pin you are using for the I2C Data line.
    	'	Subroutine Writes BYTE to External EEPROM
    SetDataExternal:
    		' I2CData - General BYTE variable
    		' I2CDeviceAddress - Hardware Device Address - BYTE variable
    		' I2CDataAddress - Address in EEPROM - WORD variable
    	I2CDeviceAddress=$A0
    	I2CWrite SDA,SCL,I2CDeviceAddress,I2CDataAddress,[I2CData]
    	Pause 10
    and the opposite to read...
    	'	Subroutine Reads BYTE from External EEPROM
    GetDataExternal:
    	I2CRead SDA,SCL,I2CDeviceAddress,I2CDataAddress,[I2CData]
    For further information lookup the I2CREAD and I2CWRITE commands in your PBP manual and compare the examples against the EEPROM Datasheet.
  1. Data EEPROM gets clobbered during programming
    By BrianT in forum mel PIC BASIC Pro
    Last Post: - 18th July 2008, 02:46
  2. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  3. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  4. Internal EEPROM Read/write Addressing Errors with 18F PIC's
    Last Post: - 12th July 2005, 19:42
  5. Sinus calculating !
    By Don Mario in forum mel PIC BASIC Pro
    Last Post: - 28th November 2004, 23:56
