Fatal Error 301: Out of Memory
Results 1 to 4 of 4
    TheBeast73's Avatar
    TheBeast73 Guest
    Default Fatal Error 301: Out of Memory
    I'm getting the fatal error 301: out of memory when i try to compile and don't know how to fix it.
    The program was compiling fine 5 minutes prior. I read somewhere to use a DOS shell, and i'm an idiot and don't know what to do. Please help, insults welcome, as long as it comes with advice.
    Default Which ver. Windoze?
    Hello Mr Beast,
    Which version of windows are you runnig? This manner of error usually occurs when 2 programs attempt to use the same place in memory. I would reboot and shut down any programs I didn't need to have open, use Control alt delete to see whats running and shut them down. If this persists check to make sure swap file is enabled, let windows manage it, I. E. virtual memory. These recommendations are for win 95/98 and Misrable Edition, if you have XP sorry I have no answer.
    JS
    edit: I just read Melanies post about pm.txt http://www.picbasic.co.uk/forum/showthread.php?t=555
    read below:
    301 Out of Memory
    Indicates that the symbol table, macro table and other memory requirements
    for internal bookkeeping have exceeded the memory capacity of your PC.
    While this error message is unlikely, it can occur on limited or heavily
    burdened systems. If not already at the 640K limit for conventional memory,
    add memory. Unloading or loading high of TSRs and network drivers can
    increase usable memory. Memory may also be gained by reducing the number of
    BUFFERS and FILES allocated in CONFIG.SYS.
    Try compiling with PBPW instead of PBP. If I'm not mistaken that should take care of it.
    /Henrik Olsson.
    TheBeast73's Avatar
    TheBeast73 Guest
    Thanks folks
  1. fatal error out of memory (pbpw.exe)
    By hardcore in forum mel PIC BASIC Pro
    Last Post: - 14th March 2010, 19:13
  2. fatal: out of memory (pbpw) error
    By ardhuru in forum mel PIC BASIC Pro
    Last Post: - 24th February 2009, 08:33
  3. Error - Fatal Out Of Memory ( With Array)
    By stormdacta in forum mel PIC BASIC Pro
    Last Post: - 26th August 2007, 14:36
  4. Need the code to write to a memory
    By Hamlet in forum General
    Last Post: - 20th August 2007, 00:22
  5. fatal error [301] out of memory with 4 lines of code????
    By George in forum mel PIC BASIC Pro
    Last Post: - 27th October 2005, 21:26
