PIC16F84A using pulsout and TMR0
Results 1 to 33 of 33
    Just as Joe says, the two resistors forms a voltage divider that "divides" the voltage fed to it by the ratio between the two resistors. The upper one is 2.2 times larger than the lower one so will loose 2.2 times as many volts over that one than over the lower one. Or if you wish to put ohms law to the test:
    The total resistance is 3.2k, with a voltage of 15V there will be a current of (I = U / R) 4.6875mA flowing thru the two resistors. Now that current will produce a voltage over the lower resistor of (U = I*R) 4.6875V.
    Since the PIC's AD pin is connected in parallel with the lower resistor the PIC will "see" a voltage between 0 and 4.6875V when the voltage from the solar PV is between 0 and 15V.
    Now, in the code I showed you we set the ADCON1 register in a way that the ADC uses the PIC's powersupply as a reference voltage. What that means is that whatever the powersupply voltage is at the moment will produce the max reading from the ADC, so for the above to work it's important that the powersupply is stable at 5.0V.
    We also said
    DEFINE ADC_BITS 10
    What that does is set the ADC code to give you a resolution of 10bits, or put another way, the result from the ADC will be between 0 - 1023. That is 0V on the input will give you 0 in SolarVoltage and 5V in will give you 1023 in SolarVoltage. The display will show that value, not the voltage.
    To get the display to show actuall volts you need to scale the value. With a powersupply of 5.0V each bit in the ADC result is 0.00488V (5/1024) so if the display shows 958 the voltage at the PIC pin is ~4.67V which in turn corresponds to ~15V from the solar PV. (See the voltage divider)
    Are you going to display the "real" voltage or just using the value to decide when to start the motor? If the later then you don't need to scale it at all, just use it as it is.
    The DEFINE ADC_CLOCK 3 tells the ADC module inside the PIC what clock source to use. It has nothing to do with the Xtal you are using to drive the PIC.
    /Henrik Olsson.
    Default Just a simple add-on
    and '3' comes from the datasheet in the ADCON1 register setting (register 11-2, page 128) ADCS2 table
    Nov 2006
    Post A/D input
    Thanks to all the reply.
    I really appreciated it. I will try it at lab.
    Actually, I would like to receive A/D input from solar PV and after that there are 2 things to be done.
    First, IF the A/D input is less that 2 volt then stop the motor ELSE the motor activated.
    Secondly, at the same time A/D input from the solar pv is sent to the computer for processing and collected the data for every 15 minute. The result will be calculated and show in graph.
    It would need some knowledge of the visual basic as database and link between vb and ms excel.
    Somebody can guide me thru this?? Thank and please give advice.
    Just compare the value you get from the ADC with the value that corresponds to 2V, if higher then run the motor, if lower then stop it, you can figure that out. You may need to introduce some hysteresis around the threshold.
    Then send the value to the PC using the PBP's SEROUT command, or even better use the USART, a MAX232 level shifter and the HSEROUT command, see the manual. There's many examples on the forum.
    For the PC/VB side have a look here: http://www.rentron.com/VisualBasic.htm
    Just send the raw value from the PIC and use VB to scale it to volts if you like.
    /Henrik Olsson.
    Nov 2006
    Post Problem
    I had try the program that you gave me. It is work.Thank.
    Some problem has finding out....
    ***********'Produce squarewave on PortB.0 period~4.32s, 50% dutycycle.
    Loop var Word
    High PortB.0
    For Loop = 0 to 2160 'Loop here for ~2.16s, tweak to match.
    PauseUs 1000
    Next
    Low PortB.0
    PauseUs 1000
    Next
    Goto Main**********
    The above is the code that you posted to me. Thanks to you again.
    I had modify it like the code below:-
    Loop var Word
    SolarVoltage var word
    ADCON1 = %10001110
    High PortB.0
    PauseUs 1000
    ADCIN 0,SolarVoltage
    LCDOUT $FE,$1,#SolarVoltage
    If SolarVoltage = 300 then
    high motor ' motor stop
    low motor ' motor run
    If update = 1 then
    LCDOUT $FE,$C0,DEC2 Hour,":",DEC2 Minute,":",DEC2 Second
    Next
    Low PortB.0
    PauseUs 1000
    If update = 1 then
    Next
    Goto Main
    ON INTERRUPT
    'Time calculation
    Update = 1 'update diaplay after 1 second*************
    The display: ****************
    0 ' when increase the A/D input, the value
    00:00:00 'increase to 0 then 1 then 2 then
    **************** 'maximum is 3
    Yes, you are correct, that will never work.
    A couple of things.
    1) The timing to produce the pulses to the motor is depending on the For Next loop and the PauseUS. When you insert a whole lot of other commands in there the timing will be WAY off. For example, the ADCIN alone will take at least 50uS, remember the DEFINE ADC_SAMPLEUS 50 then comes the LCDOUT which will take a "lot" of time also.
    Do you need the LCD to update 1000 times / second? That is what it's trying to do since you put it inside the FOR-NEXT loop.
    2) It is the For Next loop that pulses the step line to the motor. What are you trying to do with the high motor, low motor? Do you have an enable signal to the motordriver that is mapped to motor
    3) There's code missing in the INTERRUPT routine and the ON INTERRUPT statement should be at the beggining of the program with a LABEL telling it where to jump when an interrupt occurs.
    4) The ADC DEFINES are missing.
    5) The TRIS register set-up are missing.
    6) The motor variable(??) declaration is missing.
    7) You are checking if the SolarVoltage varible is equal to 300, so even if all the rest where OK the motor would only run when the value was exacly 300. You need to check if it's higher than 300.
    This is probably not the best way to this now that you are adding more and more stuff to it but it may get you going if you have decided to go this route instead of the interrupt and tick counting we also showed you.
    Again, this is completely untested! You will probably need to tweak the 2160 value in the For Next loop a little bit to get the correct timing.
    Loop var Word                     'Loop variable for the FOR-NEXT loop
    SolarVoltage var word           'Raw value from ADC
    RunMotor var bit                  'Enable bit for step pulse routine.
    DEFINE ADC_BITS 10             'Set ADC to produce 10bits
    DEFINE ADC_CLOCK 3            'Set ADC clock to internal RC
    DEFINE ADC_SAMPLEUS 50     'Set conversion time to 50uS
    TRISA.0 = 1                         'Set RA0 (pin2) to input.
    TRISB.0 = 0                         'Set RB0 as output, step pulse to motor.
    ADCON1 = %10001110           'Set RA0 to analog, internal Vref, result right justified. (See datasheet)
    RunMotor = 0                       'Do NOT run motor
    '//The IF statement here checks the flag to determine if the motor should be run or not.
    '// If it should be run the For-Next loop is executed.
    If RunMotor = 1 then                     'Produce pulses ONLY if supposed to....
      High PortB.0
          PauseUs 1000
        Next
        Low PortB.0
          PauseUs 1000
        Next
    Endif
    ADCIN 0, SolarVoltage                      'Get value from solarPV
    LCDOUT $FE,$1,#SolarVoltage           'Display value on LCD
    '// Here you can insert the code for sending to PC //
    '// and the LCD code for the time, if that's what your doing //
    If SolarVoltage > 300 then                'We are over the thershold
       RunMotor = 1                               'so lets enable the step pulses
       Goto Main                                   'and start over
    Else
      RunMotor = 0                                'disable the ste pulses.
    '// Since the For-next loop that produces the step pulses is not running now we insert a pause here.
    '// Otherwise the ADCIN and LCDOUT statements will execute VERY often.
      For Loop = 1 to 1000
       PauseUs 1000
      Next
    Goto Main
    When you post code please include comments so that it's easier for us to understnad what you're trying to do. Also, please see the vbCode page here: http://www.picbasic.co.uk/forum/misc.php?do=bbcode for how to post code so that it shows in a window like above.
    /Henrik Olsson.
    Nov 2006
    Default same question again eeprom finish
    If I doesnt want to use external eeprom and I had used up all the internal eeprom space. As I know there was a way to store the data in the program like below:-
    asm:
    da:1,2,23
    endasm
    I do not familiar with this could any one one lead me thru this method? Thank
    I just want to store 200 data in there.
  1. Pin won't stay high during Repeat...Until loop??
    Last Post: - 17th August 2009, 00:57
  2. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  3. Battery powered applications
    Last Post: - 22nd June 2009, 08:12
  4. COUNT is not counting again
    Last Post: - 19th June 2009, 05:52
  5. Can't ID interrupt source with this IntHandler??
