Quote Originally Posted by HenrikOlsson
Thanks for verifying that Skimask!
Steve, you are most certanly right about the timing, no LCD should need more than 100uS for data. But my advice of trying with 500 was not a very good one since I didn't know of the 8-bit clamp.
All valid points from you Steve, Dragonballs problem seems to be timing related since it works when he's using a slower clock than 4Mhz. But at 4Mhz it seems to skip the first characters, if I understood it correctly.
/Henrik Olsson.
I think the 500 idea was good enough since 500-256=244. Should be more than enough for a data delay...
Put a 5 second pause at the beginning of the program, that'll extinguish any doubt about the power up on the LCD. If that don't fix it, it's something else.
JDG
