If you look in the Modedefs.bas file or the "Serout" section of the PBP manual you will see that N9600 is defined as
N9600 = 6 ' Driven Inverted
Do either of the following
N9600 CON 6 ' Driven Inverted to declare the constant
or
SEROUT PORTA.5,6,["Hello World"]
Both should compile as you arent using any include files.
