PortA reset zero after USBINIT / Service ?
Results 1 to 5 of 5
    Jun 2006
    Angry PortA reset zero after USBINIT / Service ?
    i wonder why the portA goes zero after the first
    USBService behind an USBINIT ?
    What is the reason ? The C18 works correct. Seems a problem in PicBasic
    USBReset=PortReset ?
    Also if I use LATA.
    If i do a LATA.5=1 every milisecond, i can see that
    the Port goes to ground very often after an usbinit, not only one time.
    After about 1-2 seconds i have the full control again and all works correctly.
    cu
    www.x-sim.de
    freeware simulator software
    with real MS Force Feedback solution
    There's no problem like that here.. post your code, PIC#, Schematic... all you have on hand.
    Jun 2006
    Hi mister_e,
    are you from Melab, because u wrote it like u are ?
    Now i can say that this failure only appears if I use composite devices.
    Such as keyboard and mouse. Therefore I modified the the usb18.asm
    a little bit, because melab don't support composite. (reportdescriptor x2)
    The device works good but not the 1-2 seconds after plugin in.
    Seems like it do some reset or overwrites something.
    Have you done something like this before ?
    regards
    sirnoname
    ps. 18f2455, 2550 ...
    www.x-sim.de
    Nope i'm not from Melabs. I'm just a long time enthusiast and user
    Interesting problem so far... nope i never tried the composite stuff in my lasts USB projects... but it's sounds interesting. if you want, post it here for the community and experts benefit or in ZIP on my e-mail.
    Jun 2006
    Done now, some mistake in the asm firmware solved.
    Now i have 1xCDC, 4xHID working at same time in one device.
    Seems the chip dont like twice endpoint resets
    cu
    www.x-sim.de
  1. error worring pbp247
    Last Post: - 17th January 2010, 05:51
  2. PortA digita input?
    By MOUNTAIN747 in forum mel PIC BASIC Pro
    Last Post: - 27th January 2009, 22:55
  3. PIC's ports individual bits manipulation - how to?
    Last Post: - 27th February 2007, 23:34
  4. Can anyone help a beginner in a struggle?
    By douglasjam in forum mel PIC BASIC
    Last Post: - 6th May 2005, 00:29
  5. Replies: 5
    Last Post: - 1st December 2004, 13:49
