noobie question
Results 1 to 2 of 2
Thread: noobie question
    02GF74's Avatar
    02GF74 Guest
    Question noobie question
    I have bought a USB PIC prgrammer and want to verify that I have programmed a 16F676 device successfully.
    So my program initially was to toggle one line on port C and device configrued to use internal osciallator.
    that didn't work so I removed the int. osc code and wired up a 10 MHz crystal and capacitors but no difference - I'm pretty sure the device needs to be configured so it knows there is an external clock souce but ain't figure that one out yet - which may explain why that failed too.
    So in short, in both cases the device did not do what I expected so I have a plea for some sample code as follows:
    1. configure device to use internal oscillator
    2. config device to use external crystal
    3. some code to toggle a line on Port C at say every second so I can measure using DVM.
    I'm going trhough the device spec. sheet but is it rather hard going - any links to beginners programming guide, idealy specific to 676 device would be muchly appreciated.
    Default Noobie Help
    Hi 02GF74,
    this should get you started, if any of these cause the compiler to hang, just comment it out.
    JS
    ADCON1 = 7  'Disable A/D converter
    CMCON=7     ' DISABLE ANALOG ON 676
    @ DEVICE PIC16F676,HS_OSC
    @ DEVICE PIC16F676, WDT_OFF
    ' Watchdog Timer
    @ DEVICE PIC16F676, PWRT_ON
    ' Power-On Timer
    @ DEVICE PIC16F676, MCLR_ON
    ' Master Clear Options (Internal)
    @ DEVICE PIC16F676, BOD_OFF
    ' Brown-Out Detect
    @ DEVICE PIC16F676, LVP_OFF
    ' Low-Voltage Programming
    @ DEVICE PIC16F676, CPD_OFF
    ' Data Memory Code Protect
    ' Set to CPD_OFF for Development Copy
    ' Set to CPD_ON for Release Copy
    @ DEVICE PIC16F676, PROTECT_OFF
    ' Program Code Protection
    ' Set to PROTECT_OFF for Development Copy
    ' Set to PROTECT_ON for Release Copy
    http://ww1.microchip.com/downloads/e...Doc/40039D.pdf
  1. Extreme Noobie question 12F675
    By Jeff in forum mel PIC BASIC
    Last Post: - 22nd September 2009, 02:13
  2. noobie to PICs and PBPro... Programming question.
    By mcphill in forum mel PIC BASIC Pro
    Last Post: - 25th October 2007, 19:35
  3. Question for a math guru
    Last Post: - 22nd November 2006, 10:45
  4. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 07:49
  5. Noobie Question
    By mel4853 in forum mel PIC BASIC
    Last Post: - 2nd July 2006, 13:45
