serin string question
Results 1 to 12 of 12
    Default Hyperterminal
    Quote Originally Posted by Sam
    Hi Joe,
    Thanks for the reply, that does compile ok but it doesn't work,seems to keep sending data in a loop very fast by looking at the rx LED but nothing shows in hyperterminal.
    Hi Sam
    I can send data out from my keyboard using hyperterminal, but to save my butt I cannot receive any using it. Can you configure this with a resonator or a crystal instead of int osc, as mister_e pointed out?
    Quote Originally Posted by mister_e
    no big chance that it's going to work.
    JS
    Mar 2004
    Thanks for the help so far,
    I can send from pc to pic and rx from pic using the code below with the settings I first posted and the pic does reply "got it" when I enter an "f".
    CODE:
    loop:
    SerOut tx_pin,N9600,["waiting for f ",10,13]
    SerIn rx_pin,N9600,["f"]
    SerOut tx_pin,N9600,["got it",13,10]
    GoTo loop
    This works most of the time. But yes, I will change to a external osc and I don't have to use a 12F675, I have some 16F628A's and some F84's.
    I really need to have an example,any example of the correct syntax to recognize and reply to a defined string of char's.
    Thanks again,I'm trying to get my brain around working with serial.
    Sam
    Default check this out
    CODE:
    loop:
    GoTo loop
    Sam
    If you're using the internal oscillator and it's messing up some of the time, switch to a lower baud rate. That might cure most of the problem. Also, try adjusting your OSC_CAL value. If you don't want to do that, use SEROUT2 instead of SEROUT. With that command, you can 'fine adjust' your baud to compensate for your oscillator being a bit out of whack.
    I forget which-is-which, but I think if you get overrun errors, you're clock might be running fast, framing errors mean the clock is a bit slow (on the PIC that is).
    JDG
    Mar 2004
    Thank you all for the advice you've given me!
    I did switch from intrc to XT ceramic 4mhz and that did it! I've been able to do allot of the things that just wasn't working before changing to XT. I also did start at lower baud rates as advised here and increased them as I made sure things were working correctly.
    Thanks and best regards,
    Sam
  1. serin question?
    By sachymo in forum General
    Last Post: - 27th July 2008, 11:04
  2. SERIN from a large string
    By earltyso in forum Serial
    Last Post: - 2nd May 2008, 23:23
  3. Simple question about Serin..
    By Donat in forum mel PIC BASIC Pro
    Last Post: - 12th March 2008, 17:26
  4. Visual Basic 6 & Access 2000
    By Demon in forum Off Topic
    Last Post: - 7th September 2006, 05:39
  5. 16f872. config ports and serin question.
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 20th July 2005, 04:03
