Bad config fuse setting, 9600 baud, using internal OSC AND with Serout combination??? no big chance that it's going to work.
At least fix your config fuse setting, try with a lower baudrate first and use DEBUG.
Sure it's compile OK probably you're using PM to compile AND those
_CONFIG
_INTRC
_OSC
_NOCLKOUT
_WDT_ON
_PWRTE_ON
_MCLRE_OFF
_BODEN_ON
are considered as Label... not much!
