Serout problem
Results 1 to 40 of 95
Thread: Serout problem
    Sep 2006
    O k starting from scratches..
    I manages to do 2 different programs which dont work.
    here: http://www3.sympatico.ca/lerameur/
    do I need to configure SSPCON, or the RCSTA registers ?
    Also in your RX4.bas (maybe it was RX6.bas), you have
    Serin PortB.3, 16780, [B0]
    ----shouldn't that be serin2?
    I tried both , so many combinations....
    k
    Quote Originally Posted by lerameur
    k
    Did you get the LEDs to light up in sequence as described in the earlier post?
    And if you didn't, then why are you worried about the SSPCON or RCSTA registers... and why are you worried about those 2 registers in the first place? You're using a software-based serial commands, not hardware.
    Priorities, man, priorities....
    And after further checking.....................
    If you'd check your ttt program and read the PIC datasheet, you'll notice that RA.4 is an open-drain output...you'll never get a high logic level from it...
    If you'd check your rrr program and read the PIC datasheet, you'll notice that the TRIS statements are wrong...
    Don't assume something is broke when you just plain haven't looked hard enough... Come on,,, get on it... Get this thing working by tomorrow!!! or else!!!
    Sep 2006
    Nothing is working,
    Well the testing led part in the program works. thats it.
    The loop is looping, but as soon as I put the wire to the input port, then the signal disappear. AND no leds lighting
    k
    Ok, Ok, Ok,.............................
    Here we go again.....................
    This is getting annoying............
    There is something getting messed up somewhere, something you aren't telling me, something you are doing ahead of time, something you aren't doing in a logical sequence, something somewhere...........so.......
    Answer these 2 questions:
    1. What hardware do you have? List the PICs, the crystals, the LEDs, the TX, the RX, the switches, the pot, etc. and so and so....
    2. What is your 'master plan'? Do you intend to transfer data between 2 PICs wirelessly? Do you intend to just control a couple of LEDs wirelessly? What?
    JDG
    Sep 2006
    Pic16F88, 20Mhz crystals, Led out on portA.0,1,2 and 3
    MCRL on PORTA.5, ground pin, Vdd on 5v. NO pot, no switch, Just a wire going from PortB3 (output of serout) going to portA.4 (serin)
    if serin.. well
    START:
    B0 =0
    serout portB.3,n2400, [ $0F, $0F, $0F, $0F, $0F, $0F, $0F ]
    serin portA.4,n2400, [B0 ]
    if (B0 = $0F) then
    porta.2 =1
    porta.2 =0
    goto start
    GOTO START
    I want to transfer data to about 200feet between two pics.
    Go back to my web site, I posted a picture of the circuit
    thanks for your time
    ken
    ken
    Ok, still a lot of information missing. Is the 16F88 your transmitter or receiver PIC? You posted what I assume is the 'transmitter' code, what about the receiver hardware and/or code...in fact, don't worry about the code for right now. We're going to make sure your hardware is hooked up right.
    (P.S. I'm only going to be here for the next 1/2 hour, until 10pm CST)
    And another thing, you are using a software based serial solution, also called 'bit-banging'. By the time your serout is done, all the data is transmitted. It's not buffered anywhere. It's not done in hardware. It's like trying to use 2 telephones to talk to yourself in different rooms. You talk into one phone, run to the other room and wait for your voice to come out. It isn't going to happen. Serin doesn't have anything to do but wait for nothing. Not going to work....
    Sep 2006
    well from what you said before:
    5. Make sure the button works...in other words, you push it and an LED connected to the same PIC on a different pin lights up on software command
    I went real simple as you told me.
    So this pic is the only pic, emitting AND receiving, the yellow wire is from sending to receiving.
    k
    Last Post: - 8th March 2010, 20:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 16:46
    Last Post: - 13th December 2008, 17:11
  4. Strange SerOut Problem
    By masosi in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2007, 06:06
  5. Replies: 11
    Last Post: - 13th July 2005, 19:26
