Serout problem
Results 1 to 40 of 95
Thread: Serout problem
Threaded View
  1. #11
    Default serial wireless transmitter code
    'after you've got everything else set up
    led1toggle = $56 : led2toggle = $59 : led3toggle = $5a : led4toggle = $65
    ledson = $66 : ledsoff = $69
    ledswing = $6a
    START:
    gosub trainreceiver : serout portb.2, n2400, [ ledsoff ] : pause 1000
    gosub trainreceiver : serout portb.2, n2400, [ ledson ] : pause 1000
    goto start
    trainreceiver:
    serout portb.2, n2400, [ $aa, $aa, $aa, $aa, $aa ] : return
    See that? Every time you send a command you have to train the receiver because there is more than about 5ms between commands. If you were to continuously send commands or data, you probably wouldn't need to train the receiver. But in any case, you MUST use manchester encoding! You'll get garbage at the output if you don't!
    As this code is setup, all your LEDs should come on for a second, turn off for a second, come on for a second, etc.etc...
    Let me know what happens...
    JDG
    Ok, I just saw the post about using the pot. So use the pot to turn the LEDs on and off. Then after that works, use the POT to turn the LEDs on in sequence to match the pot's rotation.
    if b0 < 64 then gosub trainreceiver : serout portb.2, n2400, [ led1toggle ]
    if ( b0 > 63 ) and ( b0 < 128 ) then gosub trainreceiver : serout portb.2, n2400, [ led2toggle ]
    if ( b0 > 127 ) and ( b0 < 192 ) then gosub trainreceiver : serout portb.2, n2400, [ led3toggle ]
    if ( b0 > 191 ) then gosub trainreceiver : serout portb.2, n2400, [ led4toggle ]
    Last Post: - 8th March 2010, 21:58
  2. Serout to serial servo
    By azmax100 in forum mel PIC BASIC Pro
    Last Post: - 12th August 2009, 17:46
    Last Post: - 13th December 2008, 18:11
  4. Strange SerOut Problem
    By masosi in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2007, 07:06
  5. Replies: 11
    Last Post: - 13th July 2005, 20:26
